- Thank you received: 3
3 years 9 months ago #260783
by TimGow
Replied by TimGow on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hello,
I am following the Remora documentation for Linuxcnc Installation on a Pi 3B+, but I am have difficulties such as the frozen rainbow screen upon reboot.
I have tried a couple of class 10 sd cards (Transcend 8GB and Scandisk Ultra 32GB) and the Pi is powered by the official white AC power supply (low power often cited in rainbow screen problems). This procedure is the same as linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html .
Is it appropriate to use a Pi 3B+ with the linux-image-4.19.71-rt24-v7l+ Realtime kernel?
or just forget it and buy a Pi 4?
Is the Debian Bullseye 2022-09-22 OS appropriate for the starting point?
Is a 32GB sd card large enough?
Is there an alternative procedure to create the sd image?
3 years 9 months ago - 3 years 9 months ago #260900
by elovalvo
www.linuxcnc.org/iso/linuxcnc-2.8.1-pi4.zip
is for Pi 4
linuxcnc.org/docs/html/getting-started/g...lling_on_raspbian_10
which also works on Pi 3B+ ( v71+ for armhf)
Anyway I'm preparing an image with buster and LinuxCNC 2.8.4 32 bit for 3B+, Pi 4 and Pi400[/quote]
Replied by elovalvo on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
You can't use that procedure on 3B+ because the imageHello,
is for Pi 4
I think you can use 3B+ but there are more updated realtime kernelsIs it appropriate to use a Pi 3B+ with the linux-image-4.19.71-rt24-v7l+ Realtime kernel?
No, if you want to use LinuxCNC version 2.8.4. This version runs with BusterIs the Debian Bullseye 2022-09-22 OS appropriate for the starting point?
yes, 8 GB is enough to work even if 32 is obviously betterIs a 32GB sd card large enough?
yes, for example thisIs there an alternative procedure to create the sd image?
Last edit: 3 years 9 months ago by elovalvo.
The following user(s) said Thank You: TimGow
3 years 9 months ago #260933
by elovalvo
The image can be downloaded from this link
forum.linuxcnc.org/9-installing-linuxcnc...erry-pi-3b-pi#260915
3 years 9 months ago #260964
by TimGow
elovalvo,
Thank you very much for your generous reply to my beginner LCNC questions and your time in providing the image.
I'm away from my CNC due to work but I will use your guidance asap.
Kind regards,
Tim
Kind regards,
Tim
The following user(s) said Thank You: elovalvo
- 4170-thomasnobi
3 years 9 months ago #261563
by 4170-thomasnobi
Replied by 4170-thomasnobi on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Thanks for the replay.
Do you have any idea why the hardware PWM mode does not work (no response at PIN). As software PWM the PIN works. I have already tested some but everywhere the same software ok but hardware no reaction. I need 1kHz or better even more, which the software PWM does not provide. Or is a pin from Rasperry also possible to use?
"Thread": "Servo",
"Type": "PWM",
"Comment": "PWM Laser",
"Hardware PWM": "True",
"SP": 0,
"PWM Pin": "PD_15"
"Thread": "Servo",
"Type": "PWM",
"SP": 0,
"PWM Pin": "PD_15"
3 years 9 months ago #261570
by Aaroncnc
Replied by Aaroncnc on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Only certain pins can do hardware PWM.
What board and software branch are you using?
Time to create page: 0.296 seconds
