2 years 2 months ago #306825 by scotta
It's very very early days, but I've managed to send SPI packets on a RPi 5 from LinuxCNC using the low level RP1 memory mapped peripheral. Hopefully we can get RPi 5 support for Remora up and going.
The following user(s) said Thank You: Bari, tommylight, cakeslob, iforce2d
2 years 2 months ago #308298 by iforce2d
I came across this a while ago, have not looked into it though:
github.com/praktronics/rpi5-rp1-spi
Sounds like it's probably a bit late now to help you out much, but just thought I would mention it anyway.
2 years 2 months ago #308341 by scotta
In fact, it is that exact work that has got me started. A great starting point to build from.
2 years 2 weeks ago #312069 by 3dtech_ks
2 years 2 weeks ago #312088 by cakeslob
I think the remora w5500 firmware is only for stm32, and not for the LPC1768/9
2 years 1 week ago #313156 by scotta
Raspberry Pi 5 support
As you may have seen in the rp1lib thread, I've been working on RPi 5 SPI support for LinuxCNC. It's ready for some testing and feedback!
github.com/scottalford75/Remora/tree/mai...omponents/Remora-spi
This version of the Remora component will detect which Raspberry Pi version it is running on and load the appropriate SPI and GPIO drivers, BCM2835 or rp1lib.
For the Raspberry Pi 5 there is future features that will need to be added to the loadrt command line:
  1. The RPi 5 has 5 SPI instances available on the header
  2. Each SPI instance has a choice of 2 - 4 chip select GPIO pins
  3. Different method to configure frequency
For those that wish to test, remember this is a Beta version. Bugs may still be present.
The following user(s) said Thank You: tommylight, pocovolvedor
Time to create page: 0.451 seconds
