2 years 6 days ago #313236 by cakeslob
anyone looking to use the new thing with RPi5, keep in mind, you need to use the new firmware also. Right now Ive added a precompiled firmware for octopus446 and more will be added later but you can compile your own in the meantime
2 years 6 days ago #313267 by scotta
Yes, good point cakeslob. The new component includes the spike filter and relies on the raw count feedback from the controller board, not the DDS accumulator value. A good opportunity to migrate to OS6 firmwares and legacy the OS5 versions.
2 years 5 days ago - 2 years 5 days ago #313286 by cakeslob
fuck i dropped my octopus and broke the sdcard on my way to testing bench.
but our first catch of the day -
Nucleo f446 doesnt want to reconnect to RPi5. after the first time i connect to linuxcnc, the nucleo doesnt reconnect unless i reset the board. otherwise i get bad spi data, will investigate further.
doesnt happen on rpi4
my little STM32F411 board works great every time for some reason
edit, tested with my second favorite octopus, and everything seems fine, i will chalk this one up to jankly nucleo
i like how fast this rpi5 is
Last edit: 2 years 5 days ago by cakeslob.
2 years 4 days ago - 2 years 3 days ago #313367 by OttoJiang
Does it support BTT SKR PRO V1.2?Should I edit the source code and recompile the firmware for it or just use  BTT_407?BTT SKR PRO V1.2's MCU is STM32F407ZGT6 teamgloomy.github.io/skr_pro_1.2_pins_3_5.html
I tried to add BTT SKR PRO V1.2 to the custom_targets.json, mbed_app.json and edit main.cpp.After compiling it, I got the fiemware.bin.I wll test it when my RPI is delivered.
File Name: SKR_PRO_V1_2.zip
File Size:119.94 KB
Last edit: 2 years 3 days ago by OttoJiang.
2 years 2 hours ago #313629 by Masiwood123
Greetings,
I have two nvem cards, I can't read all 80 pages of the post related to the implementation on linuxcnc, can you explain step by step the procedures of a short way to implement them on linuxcnc, in the shortest possible terms for those of us who have very little knowledge about programming. thank you
2 years 2 hours ago #313630 by scotta
Best to start with
www.forum.linuxcnc.org/18-computer/44828...c300-ec500-cnc-board
The board you have is an STM based board, which was the first Ethernet board to be supported. So the early part of the above thread covers the development and firmware installation stuff.
The following user(s) said Thank You: Masiwood123
Time to create page: 0.121 seconds
