Touch Screen Survey
  • ALittleOffTheRails
  • ALittleOffTheRails's Avatar
  • Visitor
  • Visitor
04 Jan 2022 20:14 #230795 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Touch Screen Survey
I've got a ex POS (not that POS the other POS) 3M touch screen. 17" maybe.
Was a PITA to sort out, but I found a nifty little utility that works a treat to sort the settings out. $25 off ebay. It's a weight thing.
One of my favourite quotes from Snatch.
Boris 'The Blade' Yurinov : [referring to Tommy's gun] Heavy is good, heavy is reliable. If it doesn't work you can always hit them with it.
04 Jan 2022 23:26 #230807 by JohnnyCNC
Replied by JohnnyCNC on topic Touch Screen Survey
I'm using a ASUS  VT229H  which is a 21.5 inch multi-touch FHD screen. This screen was plug-N-play for me.  I would rather it didn't have a glossy screen but at least that makes it easy to clean and is durable.  I tried throwing chips as large chips at the screen directly at a button to see if I could get it to trigger the button and it never did. I really love this screen. I am using it with QTDragon on a mill.
  • Roguish
  • Roguish's Avatar Topic Author
  • Elite Member
  • Elite Member
06 Jan 2022 18:08 #230973 by Roguish
Replied by Roguish on topic Touch Screen Survey
I have finally purchased an Elo 27" for my mill project.  Ebay special.  It works pretty good.  Even with gloves on.
Every now and then the touch does not come on, but a quick reboot cure that.
Bigger is better.
I'm using a slightly customized QtDragon gui.
07 Jan 2022 14:02 #231028 by Jake
Replied by Jake on topic Touch Screen Survey
I have 17" ELO on the mill and plasma/router.
The ELO was easy to get up and going. They are panel mounts which I fabbed up control consoles for. It works really well. (Even with AXIS)
Time to create page: 0.229 seconds
