- CBollweg
- Visitor
Hi Scott,
I have now set up Linuxcnc again. Still, Linuxcnc works until a key is pressed on the NVMPG. I started linuxcnc from the terminal and it says the ethernet connection was lost. Once the EC500 has been de-energized and energized again, Linuxcnc continues to run without any problems until a key is pressed on the NWMPG. So the NVMPG seems to be interfering with the Ethernet connection.
Hi Christian, sounds like the behaviour of the earlier firmware. I've cleaned up my Github so that only the latest tested firmware is there. I've tested this firmware with my NVMPG and it's working as expected.
github.com/scottalford75/Remora-EC500/bl...C500-STM32-1.0.0.hex
You are my hero. With the new firmware everything works as it should. Terrific. Now it can go on. Thank you very much for your work, your development and your support
- scotta
- Thank you received: 486
- Cold Turkey
- Thank you received: 14
For sure, and if you were interested in the Expatria Teensy grbl PCB from Russell we'll send that with it.
I'm interested to know if they have been "upgraded". If it's a newer version than the one I have, even an STM32 I'd welcome the donation so that I can confirm the analogue output is working. I've not been able to get it working on my version of the board.
- scotta
- Cold Turkey
- Online
- Thank you received: 7298
Please delete the e-mail, robots are capable of reading that easily!
- Online
If not, let me know so i can remove it.
- scotta
- Aanvragen0903
- Thank you received: 3
Hi Scott,
Can you confirm iff the 0-10 volt is working?
- epineh
- Thank you received: 27
