  • scotta
  • Platinum Member
  • Platinum Member
10 Sep 2022 21:03 #251646 by scotta
The "old" versions of the NVEM and EC500 can still be supported to bug fixed. The boards are 99.9% working. Just attempts to get higher step rates will need to stopped.
  • scotta
  • Platinum Member
  • Platinum Member
10 Sep 2022 21:05 #251647 by scotta
The newer EC500's will have this different MCU aswell I'd imagine.
There is a new EC300 which apparently has the same MCU as the new NVEM. I'll confirm when it arrives in a few weeks. The EC500 appears to be discontinued with no one shipping / cancelling orders.
10 Sep 2022 21:11 #251648 by Murphy
I don't think it's canceled. They pulled the current stock. Iv emailed them and they said the model is getting "upgraded".
10 Sep 2022 21:34 - 10 Sep 2022 21:35 #251651 by Aanvragen0903
Replied by Aanvragen0903 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Would it be wise to make a manual how to do things step by step for all versions because everything is now mixed
Last edit: 10 Sep 2022 21:35 by Aanvragen0903.
The following user(s) said Thank You: Domi, DarkPhoinix
  • scotta
  • Platinum Member
  • Platinum Member
10 Sep 2022 21:40 #251653 by scotta
I really need to update the docs to include the ethernet versions.
remora-docs.readthedocs.io/en/latest/
10 Sep 2022 23:33 - 10 Sep 2022 23:34 #251659 by RogEnk
Hi all, I have uploaded two high resolution images to one of my websites and am posting the links here for posterity if indeed the NVEM is now a dead end:
Last edit: 10 Sep 2022 23:34 by RogEnk.
The following user(s) said Thank You: Bari
  • scotta
  • Platinum Member
  • Platinum Member
10 Sep 2022 23:41 #251660 by scotta
Thanks Rog, absolutely great!! I'll start to see if I can trace things. I've also ordered stencils and solder balls to reball the chip, just in case we need to lift the RT1052 to work out the circuit.
11 Sep 2022 00:32 #251661 by epineh
What sort of bugs are we talking ? I understand dropping the higher step rates for these versions but as I have one making its way to me I could still use it on a more simple machine that doesn't need fast step rates.
11 Sep 2022 00:44 #251662 by Bari
  • scotta
  • Platinum Member
  • Platinum Member
11 Sep 2022 02:12 #251663 by scotta
None that I'm aware of, but you never know what people discover as they start to use the board.
Time to create page: 0.377 seconds
