3 years 2 months ago #278728 by MotoMishka
The raspberry pi debug probe arrived and i was able to flash the board using pyocd. I tested both remora and original firmware.
Now the adventure continues with HAL configs.
Many thanks Scott!
The following user(s) said Thank You: scotta
3 years 2 months ago #278930 by Ray_TL00
Hello, I am a total newbie to Linux and linuxcnc and I know little about electronics and programming, even so, and I tried to read practically all of this topic, see the queries and answers, but it is quite extensive and I have questions. I hope the language is not a limit for me. Is this project fully finished yet? Is the connection of the stlink v2 to the board only made once to introduce the firmware or do you have to do it every time you want to change the configuration? Where should I start studying to at least be able to do the most basic?image missing /media/kunena/emoticons/ermm.png
3 years 2 months ago #278955 by scotta
Hi, welcome to LinuxCNC. There is a learning curve, which I'm sure the community here will be happy to help you.
Remora is an active project, with support / development ongoing for many different controller boards including the latest RT1052 Ethernet boards. So can't really call it a fully finished project, they never are....
The use of a CMSIS-DAP probe is only need when changing / updating the boards firmware. Configuration is performed by uploading via Ethernet.
What would you like to study, LinuxCNC or Remora setup?
3 years 2 months ago - 3 years 2 months ago #279066 by frayja2002
HI there.
Could someone please have a look at my setup here.
I am getting the dreaded joint following errors (My weed dealer is lost again) when jogging the x axis but not when jogging the others.
As far as I can see the x & y should be setup the same (except for the table size)
Can any one see why it should happen on the X but not on the Y or Z.
I should also mention that I am using Remora-rt1052 on an EC500.
Last edit: 3 years 2 months ago by frayja2002.
3 years 2 months ago #279099 by Ray_TL00
I would like to study linuxcnc, I am referring specifically to the NVEM V2 card that I have and I could not connect it to the PC, so I want to pass the ramora firmware to operate it with Linux, and I was wondering what was the most basic where I should start to to be able to do that, thanks in advance for your answer
3 years 2 months ago #279117 by scotta
This video would be a good starting point. It was for the previous version of the hardware (STM32) so the firmware flashing is different, but the remainder of the video should be helpful.
Time to create page: 0.638 seconds
