3 years 1 month ago - 3 years 1 month ago #279999 by cakeslob
remora-docs.readthedocs.io/en/latest/sof...indle-control-simple
Im not seeing a config example in the nvem repo, but here is how we are doing it otherwise.
Change remora.SP.x to what ever is in your config, and adjust the gain to spindle rpm. I think it works out to 100/24000 . another user did this the other day, here is a snippet from his config
# spindle setup loadrt scale count=1 addf scale.0 servo-thread setp scale.0.gain 0.00416 #this will make m3 s24000 give 100% output and m3 s2400 10% net spindle-speed-scale spindle.0.speed-out => scale.0.in net spindle-speed-DAC scale.0.out => remora.SP.0 net spindle-on <= spindle.0.on => remora.output.9
edit, honestly ive been thinking the same as tux,
im surprised remora can keep up with that many steps. I need some kind of step/freq calculator
Last edit: 3 years 1 month ago by cakeslob.
3 years 1 month ago #280002 by slawekgonet
Hey,
I flashed my NVEM v5 with github.com/scottalford75/Remora-RT1052-c...ora-rt1052-1.1.0.bin
Which JSON config I should upload and which LinuxCNC sample config I should start with to get it to work with NVMPG?
3 years 1 month ago - 3 years 1 month ago #280040 by GeramyL
Ahhh okay, it seems my PWM settings on my VFD are backwards or something haha, when I put spindle speed at 0% I get 100% spindle speed, when i put linuxcnc at 100% spindle speed my actually spindle speed is 0% or well not 0% because I have a required minimum so i don’t damage the drive.
Last edit: 3 years 1 month ago by GeramyL.
3 years 1 month ago - 3 years 1 month ago #280179 by cnc-phil
Need help, please.
I successfully managed to install the firmware. At first the steppers made some cracking sound (which I thought came from being the pc not ideal with a slow clocked Pentium J5005), but I used the 0.2.1 image.
After flashing the remora-rt1052-1.1.0.bin file and uploading the config, the steppers are running smooth now.
Now I have two questions:
My Novusun NVEM v5 controller only came with a v2 manual and on my controller there are no 12V connector for the limit switches, instead there are COM connectors next to the input pins. If I connect a microswitch between COM and IN4 there are no changes in the HAL Meter visible. Should I connect the microswitch between the most right 12V and IN4 ?
And my second question, I removed the unused A, B, Z axis from the config file and some MPG config entries, uploaded the config again, but they still show up in the HALshow. Is this right? Or should I just upload the full-config? Are there any performance improvements if I delete some unused pins?
Thank you.
Last edit: 3 years 1 month ago by cnc-phil.
3 years 1 month ago #280180 by slawekgonet
On my v5 there is 12V pull-up on, for example, INP3 pin. You can check it with multimeter, there should be +12V between COM and INP3.
With `nvem-rt1052.txt` config uploaded with:
$ python3 remora-rt1052-basic/upload_config.py nvem-rt1052.txt
I see an action in HAL on `remora.input.06` when I connect COM and INP3 together.
The following user(s) said Thank You: cnc-phil
3 years 1 month ago - 3 years 1 month ago #280187 by cnc-phil
Thank you so much. I measured only 6V, but after changing the input voltage of the nvem board from 12,5V to 24V it works (now I only have to get the 0-10V spindle output working)!!
Time to create page: 0.175 seconds
