- Thank you received: 12
Thank you for your reply! Would you like to clarify that such a simulation idea is suitable for my project? So that, for example, when the spindle is cooled, a light bulb lights up, what is happening?
Hello everyone I have an NVUM V2 USB board and it is configured for Mach3. But there was a need to switch to Linux CNC. I wanted to find out from experts if I could flash such a board on Remora for LinuxCNC and whether such a system would work at all?
In order for you to understand more, a simulator \ simulator for training is going to be built, and you need to make an operator panel and the movement of the machine and the compilation of its G\M code will be shown on the screen itself. The board is needed in order to perform the basic functions of the CNC machine in the form of a simulator.
Tell me, please, will such a system work? And are there any solutions to make it work?
Hi, the USB based boards are not supported by Remora or LinuxCNC as USB is not realtime capable. However for your application if only wanting to have a simulator, why not run LinuxCNC in sim mode. There are configurations already available.
Here is the basic config which includes X, Y and Z axisHey, Scott!
Thanks for replying!
The NVEM is a v2 with a STM32F20-something.
1. Flash Remora firmware - done
Yes.
2. Installed remora-nv LinuxCNC component - done, by the sounds as the example config starts
Yes, although since I followed your video, which if I understand correctly might be a bit outdated, I accidentally installed the older component Remora-eth, and then later Remora-nv. I don't know if that could have a negative effect on anything?
3. Checked communication with the board by pinging 10.10.10.10 - done, by the sounds as LinuxCNC has come out of e-stop?
Yes, this works!
4. Uploaded a configuration file to the controller board? python3 upload_config.py yourconfigfile.txt
Well yes and no. I tried it to see that it works, but to be honest I don't know what config to upload.
As I don't have any motors connected it's hard to tell if there is any movement, but looking at the graphic inteface it does not appear to be moving.
Also when I get the "joint [0-2] following error" the machine shuts down.
