- Thank you received: 280
GeremyL has been doing some great physical testing of the DMA stepgen. Chasing down missing steps, with one theory being the lack of a direction setup time.
The ability to set the direction setup time is now available.
Code:{ "Thread": "DMA", "Type": "DMAstepgen", "Comment": "X - Joint 0 step generator", "Joint Number": 0, "Step Pin": "P1_22", "Direction Pin": "P1_17", "Step Length": 2, "Step Space": 3, "Dir Setup": 2 }, Latest source has been pushed to the repo and a testing bin file as well.
Code:Can this be backported? It doesnt look like it should have to be DMA specific, but Im not too good with computers so I figured I would ask. Also, saw you had a new repo for remora-nv docs, do you think we needed a whole new repo for the nv docs? I just figured we could jam all the nvem specific parts within the hadrware specific pages. the rest of it seems pretty much the same so it looked like we could do it all as one. Here is what I had so far for ethernet branch, I used it when I was setting up my pico-dlx board. https://github.com/cakeslob/Remora-docs/tree/ethernet
The great news is that all of the RT1052 boards will benefit from this work. So the NVEM, EC300 and EC500 will be 500khz capableCan the 1052 stepgen dma configuration be used to provide a basis for development with nvem to have a higher frequency?
Unfortunately DMA dependent.
Code:{ "Thread": "DMA", "Type": "DMAstepgen", "Comment": "X - Joint 0 step generator", "Joint Number": 0, "Step Pin": "P1_22", "Direction Pin": "P1_17", "Step Length": 2, "Step Space": 3, "Dir Setup": 2 }, Latest source has been pushed to the repo and a testing bin file as well. Can this be backported? It doesnt look like it should have to be DMA specific, but Im not too good with computers so I figured I would ask. Also, saw you had a new repo for remora-nv docs, do you think we needed a whole new repo for the nv docs? I just figured we could jam all the nvem specific parts within the hadrware specific pages. the rest of it seems pretty much the same so it looked like we could do it all as one. Here is what I had so far for ethernet branch, I used it when I was setting up my pico-dlx board. https://github.com/cakeslob/Remora-docs/tree/ethernet
