3 years 3 weeks ago #282403 by scotta
Thank you for your response, but couldn't you share these files? I'm going to use a maximum of 4 axes and see what maximum frequency I could get..
Sure, I've just dug out the old work and created a repo to share it. If you do succeed, the DMAstepgen module would need to be updated to include the improvements in the RT1052 version.
3 years 3 weeks ago #282404 by scotta
3 years 3 weeks ago #282405 by cncmiljc
Thank you for your efforts.
3 years 3 weeks ago #282408 by scotta
Following my resent failures this is what I've done and where I am at now:
- Flashed the NVEM with the Remora firmware
- Installed Raspberry Pi OS (Legacy), so Buster 32 bit
- Installed xrdp to enable Remote Desktop
- Followed the guide to install LinuxCNC at remora-docs.readthedocs.io/en/latest/sof...nc-installation.html , but since I had issues with the Pi not booting after installing the realtime kernel, I instead installed 5.15.65-rt49 according to forum.linuxcnc.org/9-installing-linuxcnc...n-raspberry-pi-3b-pi .
- Installed the Remora NVEM component
- Followed Scott's videos to configure ethernet
- Flashed the basic config to the NVEM
- I am able to ping the NVEM at 10.10.10.10
- I am able to start LinuxCNC and get out of emergency stop
- I am not able to request movement. If I do, I get "joint [0-2] following error"
I really wan't to move on and reinstall the NVEM in my CNC and continue with configuring LinuxCNC, but I'm stuck with this error.
Scott, help!
image missing /media/kunena/emoticons/sad.png
Hi, I've just put the STM32 NVEM back on the bench to retest. I could simulate your error when using the remora-eth component. With the latest firmware
github.com/scottalford75/Remora-NVEM/blo...NVEM-STM32-1.0.0.bin
And this config
github.com/scottalford75/Remora-NVEM/tre...es/remora-nvem-basic
Everything is ok.
A full chip erase can be performed in the ST-Link Utility.
Time to create page: 0.665 seconds
