- Thank you received: 489
Hi, the USB based boards are not supported by Remora or LinuxCNC as USB is not realtime capable. However for your application if only wanting to have a simulator, why not run LinuxCNC in sim mode. There are configurations already available.Hello everyone I have an NVUM V2 USB board and it is configured for Mach3. But there was a need to switch to Linux CNC. I wanted to find out from experts if I could flash such a board on Remora for LinuxCNC and whether such a system would work at all?
In order for you to understand more, a simulator \ simulator for training is going to be built, and you need to make an operator panel and the movement of the machine and the compilation of its G\M code will be shown on the screen itself. The board is needed in order to perform the basic functions of the CNC machine in the form of a simulator.
Tell me, please, will such a system work? And are there any solutions to make it work?
Hi Christian, you've made good progress and on the learning curve with LinuxCNC. It does get easier and there is always help out there. So don't hesitate to ask.Hi!
Please forgive my noobness, but I need some guidance, and I really hope that you guys will be able to help me out.
I'm completely new to LinuxCNC and have pretty much no knowledge when it comes to Linux besides copy/pasting commands, making simple changes in menus and editing text files. I know it's a bit backwards to start my LinuxCNC journey by using the NVEM board with Remora. Ideally I should use a board made for LinuxCNC, but the NVEM is what I have, and I would like to not spend money and the earth's resources if I don't have to.
Now, I have been able to install Raspberry Pi OS Legacy to my Pi 4b 4 Gb, as well as installing LinuxCNC and Remora and flashing my NVEM with the Remora firmware. When I start LinuxCNC with the sim.axis configuration the simulation works fine, but displays the error message "unexpected realtime delay on task 0..." when I start with remora-nvem-basic, and as soon as I try to move an axis I get the error "joint [0-2] following error".
I have not yet connected anything to the NVEM, it's currently sitting on my desk connected to the Pi, if that makes any difference.
I work as a automation engineer, and have a lot of experience with miscellaneous automation systems, but LinuxCNC is just too much at once for me
Am I supposed to Pncconf wizard to create a configuration even though I have the remora-nvem-basic? Or should I make a configuration based on the remora-nvem-basic by copy/pasting it and making changes there based on my setup?
Apparently I've missed something, done something wrong, done something in the wrong order, and I'm hoping that you guys could find it in your hearts to help a beginner out
What I'm basically asking for is guidance on what to do next that is specific to Remora and NVEM.
Thanks in advance!
Regards,
Christian
