3 years 1 month ago - 3 years 1 month ago #281810 by aaamil13
Not a Python problem, just TimeOut while trying to upload config file. Tried to upload with script and TFTP in terminal ( the file produced from script) but with no success.
tcpdump port 69 -vv
tcpdump: listening on eno1, link-type EN10MB (Ethernet), snapshot length 262144 bytes
21:04:06.187537 IP (tos 0x0, ttl 64, id 53926, offset 0, flags [DF], proto UDP (17), length 43)
    LinuxCNC.43235 > 10.10.10.10.tftp: [bad udp cksum 0x2851 -> 0x29d8!] TFTP, length 15, WRQ "config" octet
21:04:36.211690 IP (tos 0x0, ttl 64, id 61158, offset 0, flags [DF], proto UDP (17), length 43)
Unfortunately can't read debug messages on UART ( seems that TTL level shifter burned while been connected to RS232)
So i decided to compile with integrated config JSON and that is ok for me. The good news is that Version 2.0.0 with DMA is much better, the possibility to control pulse width and 500khz stepgen ( tested at 90khz and it is ok ).
Last edit: 3 years 1 month ago by aaamil13.
3 years 1 month ago #281816 by scotta
May I ask what is the advantage of DMA stepgen? Is it faster or less cpu intense? Adjustable step length seems nice.
And one more question: Can it be used for generating PWM signals or is this a completly different can of worms.
The advantage of the DMA stepgen is the increased max step rate, from ~100khz to 500khz. So people with high micro stepping or reductions will be happy.
At low step rates the DMA stepgen has way less CPU load. The reason for the max 500khz is the point where there is not enough time within the servo thread to do the calcs for all 6 axes. Which most people will never need all 6 axes to be that fast simultaneously.
For the last point, the downside with the DMA stepgen is that it is tied to the GPIO port used for the step and direction outputs, GPIO1. The other outputs are on GPIO2, which could be used with the sowftware PWM module if needed.
The following user(s) said Thank You: cnc-phil
3 years 1 month ago #281819 by oficinerobotica
@aaamil13 could you please share your ec500-rt1052.txt config file for the DMA branch? also the hal and ini files. I managed to flash the ec500 with the DMA stepgen bin, I can ping the card and bring Linuxcnc out of estop but I'm getting following errors as soon as I try to jog. I'm using the config provided by scotta in the github repo. No steppers yet attached.
3 years 1 month ago #281833 by scotta
I've just added my testing LinuxCNC config and EC500 config file to the DMAstepgen branch. Hope it works for you to. I've set the joint scales high for testing.
3 years 1 month ago - 3 years 1 month ago #281834 by oficinerobotica
Oh man .... thank you so much. I still have allot to learn.
Link for supporting your development please? :)
Edit:
In the remora-ec500.hal at line 9 I see "loadrt remora-nv PRU_base_freq=500000"  but linuxcnc will throw an error complayning of not finding remora-nv.so. I can start linuxcnc only if I change it to "remora-eth" in the hal file.
Do I have the wrong remora components compiled for  linuxcnc?
I used the remora eth branch to compile the lcnc components
Last edit: 3 years 1 month ago by oficinerobotica.
3 years 1 month ago #281843 by scotta
No need to add the base_freq parameter, The DMA stepgen is hard coded.
remora-nv component is available from the following repo
github.com/scottalford75/Remora-NVEM/tre...Components/Remora-nv
The following user(s) said Thank You: oficinerobotica
Time to create page: 0.222 seconds
