open("/tmp/config.txt", "wb").write(config)
# Upload using TFTP, set large timeout
client = tftpy.TftpClient("10.10.10.10", 69)
client.upload("config", "/tmp/config.txt", timeout=30)
It's a TFTP which differs from FTP and TFTP is configured on port 69.
I have no steps forward, PyOCD communication is timed out, and even no debug info on ComPort. Flashed with remora-rt1052-1.1.0.bin and remora-rt1052-1.0.0.bin. Flash is OK, have ping to 10.10.10.10, but not able to upload configuration file and no ComPort. LinuxCNC communicates with EC500v5, I am able to Enable and start the board from LinuxCNC, but if i try to move Axis then popup "joint 0 following error". BOOT led sets on when i press enable on LinuxCNC.
I am not sure if debug ComPort is DB9 port on EC500 or have to use some other pins.
Do I have to enable TFTP by a special procedure ( short pin, some command or etc.) and is there a procedure to enable debug on ComPort
Thanks in advance
