3 years 1 month ago #281709 by aaamil13
I think you have to remove BOOT->3.3V jumper. Just tasted with jumper and i'm not able to flash.
3 years 1 month ago #281745 by scotta
Yes, I've only ever had to use the boot button or jumper when I've locked up the firmware with bad code or not being able to connect the debug probe.
3 years 1 month ago #281768 by scotta
DMA Stepgen - beta testing
For those interested, DMA Stepgen is ready for beta testing. On the bench it's working nicely with bugs being found and fixed along the way. Appreciate some feedback on issues.
github.com/scottalford75/Remora-RT1052-c...e/feature/DMAstepgen
github.com/scottalford75/Remora-RT1052-c...t1052-2.0.0-beta.bin
The DMA stepgen is configured like below:
    {     "Thread": "DMA",     "Type": "DMAstepgen",         "Comment":            "X - Joint 0 step generator",         "Joint Number":        0,         "Step Pin":         "P1_22",         "Direction Pin":     "P1_17",         "Step Length":        2,         "Step Space":        3     },
As you will see, there is now the ability to configure the step length and space settings. These are in multiples of 1 micro second (1000ns).
With a 1 micro second step length and space you will achieve 500 khz step rate!
Of course, adjust your max velocity in your HAL setup to respect the max step rate achievable with your step setting.
The following user(s) said Thank You: tommylight, Murphy, cnc-phil
3 years 1 month ago - 3 years 1 month ago #281804 by cnc-phil
Last edit: 3 years 1 month ago by cnc-phil.
3 years 1 month ago #281805 by aaamil13
God bless you scotta, I was on my way to give up with EC500, but with the last build everything work great, except TFTP, but I rebuild it with changed default JSON. Thanks for the great work you do. Ping is between 200-400 us, stepgen works perfect with no follow error. Continue to test but for now works perfect.
3 years 1 month ago #281807 by oficinerobotica
For the tftp error try
Sudo apt install python3-pip
Pip3 install tftpy
That did it for me. Sorry for the formatting but I'm on mobile but you get the idea.
Pip3 will install the python3 tftpy module. Pip will install only for the 2.7
Time to create page: 0.400 seconds
