2 years 8 months ago #293642 by cakeslob
Hmm, that selenium is a new one
install this component
github.com/scottalford75/Remora-RT1052-c...omponents/Remora-eth
change this line in your config
github.com/scottalford75/Remora-RT1052-c.../remora-ec500.hal#L9
change it to this
loadrt remora-eth-3.0 PRU_base_freq=500000
It looks like all the configs except one are calling for remora-nv, anyone wanna do a PR to fix it?
The following user(s) said Thank You: Aravind
2 years 8 months ago #293651 by Cold Turkey
Hey guys, been away from this for a while. Awesome progress and big thanks to everyone who's making this work.
Does anyone have a config for the EC500 RT1052 with all the inputs on the MPG port working? Looked through the EC300 config but saw a lot of conflicts with other pins. I've got WHA and WHB working and will try a few more today if I get the chance.
Cheers
2 years 8 months ago #293667 by Cold Turkey
Had a little time to play with it and got the MPG working as well as pins 6,7,8and 15. Couldn't get any further and have other stuff to work on. If anyone has the info I need to get Pins 1,5,9,13 and 14 working it would be greatly appreciated.
Just want to use pins 1 and 9 as inputs... don't know if that changes anything.
Cheers.
2 years 8 months ago - 2 years 8 months ago #293747 by Aravind
Thanks for your reply.
Well I tried these steps, installed remora-eth-3.0.c and edited the file remora-ec500.hal line 9 . And I rebooted my board.
But now when I try to open linuxcnc > remora-ec500, it is showing the board is unreachable. And when I try to ping 10.10.10.10. it is showing Network is unreachable.
Previously I was able to open Linuxcnc and when I tried to exit e-stop the Red LED light near to the ethernet port was blinking. Now it is not there. I don't understand what happened. Did I missed any step?
Kindly help me to solve this issue.
Edit:
[SOLVED]
The issue got resolved when I reinstalled the RPI4 image and do all the steps again with the above mentioned step.
Thanks Cakeslob. Thanks all for your support.
-Aravind
Last edit: 2 years 8 months ago by Aravind. Reason: Solved the issue
2 years 8 months ago - 2 years 8 months ago #293821 by Aravind
[EDIT]
Issue: Stepper Motor was not running
<SOLVED>
- Issue was with stepper driver.
-Aravind
2 years 8 months ago - 2 years 8 months ago #293844 by vpomerleau
Hi Everyone
I was able to flash my 2 boards and make my servo motors work with them with the DMA config:
EC500 RT1052 & EC500 STM32F407
But I have differents problems with both boards:
-My NVMPG work great on the STM32 but on the RT1052, I dont have any update on the display, is there differents components or files somewhere. The inputs and encoder are all working but nothing change on the display, it stuck at X0 Y0 Z0 while axis is moving. Maybe I also have a bad MAX3232 chip on my board, anyone know how to check this.
I before had these weird values (attached picture) but after reflashing the board everything is at 0
I use the same NVMPG on the 2 controllers for my tests, It's probably the the STM32F103RCT6 chip inside, I bought it 5 years ago.
-My other issue is with the STM32 board, I cant get the spindle 0-10V working, It's stuck at 9.7V and this was working in Mach3 . On my RT1052, it work fine and I use the same HAL spindle commands.
Any help would be really appreciated.
Last edit: 2 years 8 months ago by vpomerleau. Reason: missing info
Time to create page: 0.615 seconds
