2 years 1 month ago #310419 by cakeslob
for user xaxexa, when you say one pulse output , are you referring to it as only an A channel (x pulse/revolution) or do you mean it is a single pulse like an index channel where 1 pulse/revolution ?
if it is the index channel, you could probably implement it.
Echo to Murphy, we could benefit from having the option for only A/Z as it seems common for lathe users, , Myself and other users are finding increasing need for a non quadratic option so the encoder module can be used for MPG. Using Encoder module vs DIgitial IO for an MPG is a cleaner hal file, but also using digital IO for MPG uses 12% of the available inputs on the SPI version
The following user(s) said Thank You: Murphy
2 years 1 month ago #310486 by xaxexa
look, the square encoder gives us the direction and frequency, you can also calculate the angle and so on, depending on the accuracy of the encoder, the Z channel allows you to refer to the position of something, for the MPG Z is not needed, for stepper motor feedback, I would choose a diver with encoder support, and now I want feedback of the spindle speed, in theory it can be implemented using A encoder channel, or the Z channel theoretically could also give such functionality, I don’t need to cut threads, just feedback of revolutions per minute
2 years 1 month ago #310517 by xaxexa
Today I was sitting with a frequency generator :)
my notes, if you enter only channel A in txt, the counter counts 0,1,0,1,0,1 instead of 0,1,2,3,4,5, there is no acceleration, and velocity = 0
if you connect A and B to the same pin, then at a low frequency the counter is 0, apparently the board understands that the pulse comes at the same time, if you increase the frequency above 1 kHz, errors begin, and the counter begins to increase or decrease non-linearly, well, it seems the simplest thing is to exclude channel B from the calculation, but I don't have the knowledge at all to write such a commit... :)
and I also need to use the PRU encoder module, not just an encoder, right?
2 years 1 month ago #311041 by aDm1N
The fact that I couldn't flash the board is because it is defective for whatever reason. Is on the way back now. Now I'm wondering what happens next. Of course, getting a new NVEM would work. or would an EC300 or EC500 be a better choice? A standard MPG should be connected with individual cables, so an NVEM is probably easier at first. Mesa cards are hard to come by right now, or much more expensive. If you were faced with a choice right now, what would your decision be?
2 years 4 weeks ago - 2 years 4 weeks ago #311181 by xaxexa
help me figure it out, I'm still trying to make a frequency counter on one wire, with a QDC module, I found a solution, now in the variable pv0 I see a growing counter, with an adequate frequency exactly the same as on the frequency generator, I took the Linux module "counter", removed everything unnecessary from it, connected pv0 with raw_counts I see the value velocity, but it is with an accuracy of 1 kilohertz, how to reduce it to 1 hertz??? is this related to the servo thread refresh rate?
Warning: Spoiler!
Last edit: 2 years 4 weeks ago by xaxexa.
2 years 4 weeks ago #311187 by xaxexa
figured it out, yes it is connected with the servo thread speed... I will continue to do it...
Time to create page: 0.150 seconds
