So, the new board has arrived (NVEM). Soldered the cable and tried it quickly with Windows. It worked and I get an answer from 10.10.10.10
C:\Users\adm1n\Nextcloud\LinuxCNC_Minidrehbank\Remora-RT1052-cpp\Firmware>pyocd list
# Probe/Board Unique ID Target
0 ARM DAPLink CMSIS-DAP 070000811a5a5bb50000000001ef41eca5a5a5a597969908 ✔︎ stm32f103rb
NUCLEO-F103RB
C:\Users\adm1n\Nextcloud\LinuxCNC_Minidrehbank\Remora-RT1052-cpp\Firmware>pyocd flash remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi -v
0005355 W STLink, CMSIS-DAPv2 and PicoProbe probes are not supported because no libusb library was found. [common]
0007141 I Target type is mimxrt1050_quadspi [board]
0007232 I DP IDR = 0x0bd11477 (v1 MINDP rev0) [dap]
0007310 I AHB-AP#0 IDR = 0x04770041 (AHB-AP var4 rev0) [discovery]
0007357 I AHB-AP#0 Class 0x1 ROM table #0 @ 0xe00fd000 (designer=00e:NXP part=88c) [rom_table]
0007373 I [0]<e00fe000:ROM class=1 designer=43b:Arm part=4c8> [rom_table]
0007373 I AHB-AP#0 Class 0x1 ROM table #1 @ 0xe00fe000 (designer=43b:Arm part=4c8) [rom_table]
0007404 I [0]<e00ff000:ROM class=1 designer=43b:Arm part=4c7> [rom_table]
0007404 I AHB-AP#0 Class 0x1 ROM table #2 @ 0xe00ff000 (designer=43b:Arm part=4c7) [rom_table]
0007433 I [0]<e000e000:SCS v7-M class=14 designer=43b:Arm part=00c> [rom_table]
0007436 I [1]<e0001000:DWT v7-M class=14 designer=43b:Arm part=002> [rom_table]
0007436 I [2]<e0002000:FPB v7-M class=14 designer=43b:Arm part=00e> [rom_table]
0007452 I [3]<e0000000:ITM v7-M class=14 designer=43b:Arm part=001> [rom_table]
0007468 I [1]<e0041000:ETM M7 class=9 designer=43b:Arm part=975 devtype=13 archid=4a13 devid=0:0:0> [rom_table]
0007484 I [2]<e0042000:CTI CS-400 class=9 designer=43b:Arm part=906 devtype=14 archid=0000 devid=40800:0:0>
[rom_table]
0007499 I [1]<e0040000:TPIU M7 class=9 designer=43b:Arm part=9a9 devtype=11 archid=0000 devid=ca1:0:0> [rom_table]
0007499 I [2]<e0043000:TSGEN class=15 designer=43b:Arm part=101> [rom_table]
0007515 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0007531 I CPU core #0: Cortex-M7 r1p1, v7.0-M architecture [cortex_m]
0007547 I Extensions: [DSP, FPU, FPU_DP, FPU_V5, MPU] [cortex_m]
0007547 I FPU present: FPv5-D16-M [cortex_m]
0007574 I 4 hardware watchpoints [dwt]
0007579 I 8 hardware breakpoints, 1 literal comparators [fpb]
0007642 I Loading C:\Users\adm1n\Nextcloud\LinuxCNC_Minidrehbank\Remora-RT1052-cpp\Firmware\remora-rt1052-3.1.3.bin [load_cmd]
0007816 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0007831 I IMXRT Boot Device: 0 [target_imxrt]
[==================================================] 100%
0083752 I IMXRT Boot Mode: Internal Boot [target_imxrt]
0083763 I IMXRT Boot Device: 0 [target_imxrt]
0083889 I Erased 393216 bytes (6 sectors), programmed 358656 bytes (1401 pages), skipped 0 bytes (0 pages) at 4.60 kB/s [loader]
