1 year 11 months ago #314650 by LabOuest
Hello again,
I'm struggling with the infamous following error when I try to go faster than about 2300mm/min.
I'm running my steppers at 1000 steps/mm as is required by my application.
I've read through this topic and the stepper tuning doc but I can't seem to figured it out.
Does my servo thread latency matters ?
I'm still running the default configs beside the JOINT SCALE set to 1000.
I was also thinking that this issue could be due to the default signal timing being to long for remora to keep up.
How and where do I configure the stepgen timing with remora ?
See the attached timing requirements for my drivers.
1 year 11 months ago #314658 by royka
The latency is already high after such a short amount of time without running glxgears, so the latency might be the cause if it goes higher during operation. Isolating all cores makes no sense, you should always have one available for the system to run its tasks on. It won't hurt to try to find better settings in the bios and kernel parameters.
Network latency can also be a cause, pinning the Ethernet irq to the isolated core can help.
1 year 11 months ago - 1 year 11 months ago #314664 by LabOuest
Yeah, I was running a youtube video in the background but still, you're right, it's quite high.
I thought that this could be a possible cause so I've already made all of the recommended changes to the bios.
Thank you for the heads up on the core isolation, I must have misunderstood Talla83's video.
I will try to better understand kernel settings, unfortunately, there's isn't a lot of information about my dell optiplex 3020m.
Pinging the EC500 gives a latency between 0.130 and 0.25ms.
I'm trying to narrow down the possible causes, do you experience about the same ethernet latency as I do ?
EDIT: Using Halshow I can get so more debug information:
  • remora.read.time is between 5 to 700 000
  • remora.update-freq.time is between 4-700
  • remora.write.time is 5 to 800 000
Last edit: 1 year 11 months ago by LabOuest.
1 year 11 months ago - 1 year 11 months ago #314696 by royka
The ping latency seems to be good, mine (with mesa) gives 0.2ms. If your latency won't get higher after a longer time of testing it should be good enough.
You could try to increase the servo_period to 2000000
With an Optiplex 3040m I had good results with these parameters:
isolcpus=3 intel_pstate=disable processor.max_cstate=0 idle=poll cpufreq.default_governor=performance i915.enable_dc=0 ahci.mobile_lpm_policy=1 irqaffinity=0 nomodeset quiet
From 1x8gb to 2x2gb (of the same brand/speed) for dual channel also improved the latency
forum.linuxcnc.org/18-computer/39371-res...cnc?start=330#271127
In your case it should be isolcpus=1
If the error still appears it might be helpfull to upload your ini file.
Last edit: 1 year 11 months ago by royka.
The following user(s) said Thank You: LabOuest
1 year 11 months ago - 1 year 11 months ago #314760 by Murphy
Does this look ok to get the encoder PV1 counting? PV1 should be the MPG socket. I don't know if I have a hardware issue or code issue. Also does the nvmpg.so need to be compiled first? I'm using an adum1200 to bypass the opticouplers. PV1 does not count when I move the encoder in Halshow
Last edit: 1 year 11 months ago by Murphy.
1 year 11 months ago #314796 by LabOuest
Looks like I can rule out network latency, good.
The pc was supplied with 1x4gb, I'll try to swap it out for a dual channel combo.
Well, all hope isn't lost, thank you Royka, I'll try to move forward with the recommendation you've provided !
The following user(s) said Thank You: royka
Time to create page: 0.154 seconds
