1 year 11 months ago #315036 by Masiwood123
thank you very much, I did it, I inserted this config as well as halcompile with remora-nv.c, now there are no problems with starting, however, as before, it issues a latency error, and after a very small jog, it loses communication with the network and the only thing possible is to turn it off and turn the power supply on again and that's how it gets the network. The conclusion is that it's very unstable, so I'll try to do the same with my version1 nvem card that I have from before and compare the error, if it's still the same, it's probably the problem is in linux itself. mesa 7i96s works on it without error.
1 year 11 months ago #315039 by royka
If I remember it correctly that component doesn't work, you might want to try:
github.com/scottalford75/Remora/tree/mai...omponents/Remora-eth
and change in your hal settings to "loadrt remora-eth-3.0"
The following user(s) said Thank You: Masiwood123
1 year 11 months ago #315058 by Masiwood123
thanks for the support,i also tried with remora-eth-3.0.c, unfortunately the thing is the same with nvem1 and nvem2 cards, latency error, while it knows the network, let me turn on the machine, but very soon a joint following error appears as well as a repeated loss of the network, it's not worth it, I'll try to restore the mach3 firmware.
1 year 11 months ago #315066 by royka
The latency error right after start you can ignore or it also still gives a following error?
In the latter case monitoring the uart output will help to see if the firmware and config work correctly
1 year 11 months ago #315071 by Masiwood123
so, after starting and turning off the latency error, if there is a connection to the network, then allow the machine to turn on (if there is no connection to the network, the button for machine on is blurred, when trying to jog, it throws out joint following errors and turns off the network) I will try on another linux to I'll try, I don't understand uart monitoring at all, I tried what I know because these cards on mach3 didn't work well.
1 year 11 months ago #315077 by Thayloreing
Good evening everyone, I'm trying to read all the posts to study the remora because I'm interested in buying a nvem board, but there's a lot to read, I'm still on the way, I wanted to get ahead of the purchase of the board, what versions do the remora have? of plates so far, could you tell me? thank you in advance thank you very much
Time to create page: 0.159 seconds
