1 year 11 months ago #314803 by LabOuest
I borrowed an old pc with a very low latency of about 3-4us (still steady after 1300sec)
Unfortunately, I'm not getting any improvement, I'm still getting a following error above 2300mm/min (~38KHz)
There must be another limiting factor somewhere else, how can I improve my troubleshooting method ?
Did anyone achieve a step rate higher than 38KHz with a similar setup ?
As Royka suggested, I've tried to increase the servo period, without success. (Though, lowering it definitely makes things worse)
Also, how can I make sure that the default stepper timing are correct ?
Attached to this post, you'll find my config.
1 year 11 months ago - 1 year 11 months ago #314807 by royka
In the last line of "remora-eth-3.0.h" from the remora component the default line is:
#define PRU_BASEFREQ 40000 // Base freq of the PRU stepgen in Hz
Try to increase that frequency and recompile/install
And a quote of Scott: "Your joint max velocity needs to he higher than the overall max velocity so that a joint can try to catch up the following error."
Last edit: 1 year 11 months ago by royka.
1 year 11 months ago #314836 by LabOuest
I remember seeing Scott's post about the max velocity, I forgot to bump it up, now it's set to 2x the max gui velocity, thanks.
Increasing the base frequency did not result in any mesurable improvement, still fails at about 38KHz.
I've tried 60KHz 80KHz and 100KHz, updating each time with the command sudo halcompile –install remora-eth-3.0.c
1 year 11 months ago #314839 by royka
1 year 11 months ago #314842 by LabOuest
Understood, I'm using the basic config.
What does DMA stands for ?
1 year 11 months ago #314845 by royka
Direct Memory Access, as far as I understand is that with DMA the frequency is 500kHz and it seems that it's limited in the firmware to 40kHz otherwise. Somewhere in this topic Scott explained how it works.
The following user(s) said Thank You: LabOuest
Time to create page: 0.146 seconds
