4 years 4 months ago #244558 by scotta
I've just published the first of hopefully a few videos on setting up Remora-NVEM.
The following user(s) said Thank You: Bari, tjtr33, Clive S, Domi, spdbmp927
4 years 4 months ago #244575 by Aaroncnc
looks awesome.
I wonder what step generator they are running with mach 3 that they are able to get to 200khz
I seem to remember in an older post there was speculation to double the speed of the unit i thought that would have brought it to 80khz.
4 years 4 months ago #244588 by scotta
Thanks, and I'd love to know the original step generation scheme as well. I had another look at the decompiled original firmware but it's very challenging to understand.
The Remora-NVEM step generator now runs at the base thread frequency. It use to take two base threads to raise and then lower the step pin. I need to migrate this into the standard Remora code as well.
4 years 4 months ago #244595 by scotta
Another short video stepping through using the JSON configuration capabilities of Remora.
The following user(s) said Thank You: tommylight, Clive S, spdbmp927, satsuma
4 years 4 months ago #245496 by viewtop1
Really Great work.
Is there a difference between the "Original" Remora and the NVEM version? Does the NVEM support QEI encoder?
4 years 4 months ago #245620 by andypugh
I have been following this with interest, but with a drawer full of Mesa cards and no new machine builds on the horizon I have not tried it.
But if you want it in the main repository, let's go for it.
The following user(s) said Thank You: Domi
Time to create page: 0.222 seconds
