4 years 1 month ago #251622 by MX_Master
We can just solder out the chip using soldering station and hot fan. Any repair shops can do that work. After all the tests chip can be soldered back with re-balling technique.
4 years 1 month ago #251626 by scotta
I borrowed a SMD rework station to remove the optos from the EC500. Not sure if I'm that ambitious to attempt it. All those caps on the back of the board... :-0
4 years 1 month ago #251636 by scotta
I've installed MCUEpreeso IDE and started to research what will be needed.
The NVEM/EC300 uses the same LAN8720A PHY as the earlier versions. The RT1050 examples use a MII example not RMII but I found this article:
community.nxp.com/t5/i-MX-RT-Knowledge-B...XRT1050/ta-p/1107482
I've only found one reference to a driver on an RT1020 site.
su.0v0.us/MoblinClub/imxrt1020-template/...rd/fsl_phylan8720a.c
4 years 1 month ago #251638 by Bari
Do you think that you should start a new thread here on the forums for the EC300 with Remora if the NVEM is now dead?
4 years 1 month ago #251639 by scotta
Probably a good idea as this thread is getting quite long. Shame all the earlier work is "wasted" because of the chip shortages. I've shelved all work on the DMA stepgen as well.
4 years 1 month ago - 4 years 1 month ago #251640 by Aanvragen0903
Is it not better to first finisch the nvem and the ec500 before to move to newer versions? There are a lot of people who have the old versions.
Last edit: 4 years 1 month ago by Aanvragen0903.
Time to create page: 0.675 seconds
