- Thank you received: 14
Yeah through DigitalDream Store on Aliexpress. I just straight up asked them about what was in it, he checked with his boss and gave the answer. If you have no luck getting in touch with them just let me know what you want me to ask them and I'll have a crack.
I asked them
You've made contact...? I tried with no success.
Hi Christian, have you checked that your network adaptor is configured correctly to have an IP address within the same sub net 10.10.10.xx? Assuming you are not going through a router, When you plug the network cable into the controller board and run the ifconfig command from terminal do you see that your adaptor has an IP address?Hi Scott,
I am lost. After flashing the new Firmware it is not able to ping the EC500.
Flashing the old firmware, still the same error with the nvmpg.
Sorry for this, but i need help to solve the problem.
Thx
Christian
Hi Scott,
Hi Scott,
Thx
Christian
If you have a good IP address and still no luck pinging, I'd then move on to doing a full chip erase and reflash the firmware.
