Hi Scott, still the same. Without nvmpg it works. With nvmpg on it shows the coordinates but goes in estop as soon as i push any button. After this the terminal says the connetction to the card is lost. Any idea?Hi Christian,
I've check the EC500-full-config.txt and found an error that my (or may not) be the cause. In the AIN input, the pin was wrongly set as PC_1 where it should be PD_1. This has been corrected in the repo now.
PC_1 is actually used for the Ethernet, not sure if this was the cause. I still need to get my serial working to test further.
Hi, thanks but how are your setting the Base Thread frequency? From the HAL file or by compiling?
Note that PRU_BASEFREQ must be the same in both the LinuxCNC component (or from the loadrt command) AND in the firmware otherwise your frequency scaling / speeds will be wrong.
Strange... did you import the project into STM32cubeIDE or just open the folder directly. Both the debug and release profiles should have UDP working. The debug profile has caused some timing issues in Mbed because of the additional debug code compiled in.
