4 years 2 months ago #250053 by scotta
I received my EC500 and NVMPG yesterday. Firmware uploaded and running so far apparently. However, when the handwheel is connected, Linuxcnc goes into estop and I get the following error. The EC500 must then be switched off and restarted, since Linuxcnc no longer comes out of the estop. does anyone have an idea or is remora not ready yet?
Hi, I've not got the NVMPG running with my EC500 as the serial communication on my board does not seem to work correctly at high speed. Can you share a picture of your board? If it's similar to the NVEM then we will be close to getting it working. When you say LinuxCNC goes into estop, when does this occur? When you try to jog?
  • New Member
  • New Member
4 years 2 months ago #250058 by
4 years 2 months ago #250059 by scotta
on nv
? a photo would be great as there are at least two versions of the board.
  • New Member
  • New Member
4 years 2 months ago #250062 by
  • New Member
  • New Member
4 years 2 months ago #250063 by
Hi Scott,
it reacts differently. If the board is switched on with the hand wheel plugged in and Linuxcnc is running, the coordinates are displayed correctly. As soon as I press any button on the handwheel, Linuxcnc goes into estop and shows the following error. If plug in the handwheel with the board switched on, linuxcnc goes into estop immediately.
4 years 2 months ago #250068 by han
Hey, sorry for stupid question in advanced, you might have answered it before but might have missed it.
Was wondering if there is a way to catch signals from inputs. Looking through forum I saw a way to configure joint, tried similar way to do with input but with a failure. In the end would love to see if I can get input to register as machine homing when it reaches the trigger(s)
Thank you in advance!
Time to create page: 0.158 seconds
