4 years 1 month ago #251075 by scotta
Hi Russell,
With the current DDS step generator the step rate is the same regardless of the number of axes. It will max out between 80 - 100khz I think. The work I've been doing with the DMA stepgen, I hope pay off and give higher step rates. For this version the max rate may be dependent on the number of axes.
Yes, that is the NVEM board, you may also be interested in the EC500 which I think is a nicer board IMO.
4 years 1 month ago - 4 years 1 month ago #251076 by epineh
Righto, I will look at the EC500 as well.
Thanks for all you've done so far, fingers crossed for higher step rates.
Russell.
Last edit: 4 years 1 month ago by epineh.
4 years 1 month ago #251080 by scotta
Some good news regarding the NVMPG for the EC500. It is now working. I had to modify the version of the EC500 I have to remove the opto couplers between the MCU and MAX232 IC. Serial would work a 9600 baud but nothing higher, the optos were just not fast enough. The newer version of the board does not have these so I was pretty sure they were the culprit.
A bit fiddly to remove, but well worth it.With the optos removed I was able to get the serial comms working and noted that I had not updated the DMA RX interrupt handlers from the NVEM version of the code.
So all working now and ready for testing.I've got issues pushing updates to the Remora-Novusun repo so have had to create a new Remora-EC500 repo temporarily. The latest bin file is here github.com/scottalford75/Remora-EC500/tree/main/Firmware
4 years 1 month ago #251081 by Murphy
If you manage to get an EC500 shipped could you let me know please. Iv just had another board cancelled by the seller after waiting two weeks.
4 years 1 month ago #251082 by epineh
When you say the EC500 is a nicer board are you referring to the connections/layout or does it have functions that the NVEM doesn't? I see it has a higher pulse rate written on it, I understand that probably doesn't matter with how we are using it here. The NVEM is slightly cheaper but if it performs better then I'll go with the EC500.
4 years 1 month ago #251083 by wazza77
Hi Murphy,
I Orderd mine about 10 days ago and they shipped it 2 days ago Aprently she has it in stock www.aliexpress.com/item/1005004153839534...t.0.0.21ef1802lzszVQ
Time to create page: 0.401 seconds
