- Thank you received: 5
Hi Christian, sounds like the behaviour of the earlier firmware. I've cleaned up my Github so that only the latest tested firmware is there. I've tested this firmware with my NVMPG and it's working as expected.I have now set up Linuxcnc again. Still, Linuxcnc works until a key is pressed on the NVMPG. I started linuxcnc from the terminal and it says the ethernet connection was lost. Once the EC500 has been de-energized and energized again, Linuxcnc continues to run without any problems until a key is pressed on the NWMPG. So the NVMPG seems to be interfering with the Ethernet connection.
Hi, Remora has been ported to F103, F207, F407, F429, F446.jlcpcb.com/partdetail/Stmicroelectronics-STM32F407VET6/C28730 currently 11k in stock
Scotta, Do you have a list of currently supported stm32's? or do I have to dig into source
I'm interested to know if they have been "upgraded". If it's a newer version than the one I have, even an STM32 I'd welcome the donation so that I can confirm the analogue output is working. I've not been able to get it working on my version of the board.Well I will let you know when they get here and what they are. If it would be of assistance, I'm happy to donate one of them to Scott.
Hello Scott,
