- Thank you received: 93
Hello Scott,
Hi Scott,
I am lost. After flashing the new Firmware it is not able to ping the EC500.
Flashing the old firmware, still the same error with the nvmpg.
Sorry for this, but i need help to solve the problem.
Thx
Christian
Hi Christian, have you checked that your network adaptor is configured correctly to have an IP address within the same sub net 10.10.10.xx? Assuming you are not going through a router, When you plug the network cable into the controller board and run the ifconfig command from terminal do you see that your adaptor has an IP address?
If you have a good IP address and still no luck pinging, I'd then move on to doing a full chip erase and reflash the firmware.
Hi Scott,
ip address is 10.10.10.1. So i did a full chip erase and reflashed the firmware from this " github.com/scottalford75/Remora-EC500/tree/main/Firmware ". A ping on 10.10.10.10 says host unreachable. So i erased the chip once again an flashed the firmware from " github.com/scottalford75/Remora-Novusun/...are/Remora-EC500.bin " And the ping on 10.10.10.10 has good results. But there is still no change with the nvmpg with this version of firmware. I don't know what I'm doing wrong. I am very sorry for causing you such inconveniences.
Christian
Christian,
A few more things to check. Below is my wiring which is known to work. RX <--> TX.
Have you uncommented the line in the INI file to enable the NVMPG?
Code:[HAL] HALFILE = remora-ec500.hal # remove comment from next line to enable the NVEM NVMPG HALFILE = remora-nv-mpg.hal POSTGUI_HALFILE = postgui_call_list.ha HALUI = halui
