3 years 6 months ago #268635 by scotta
Hi all
I have just flashes a EC500 board with the new firmware & can confirm that it is working great. I've tested the inputs & they are all working as expected & judging by the lights all the outputs are working.
Most importantly the spindle output now turns off when directed to goto 0 rpm (Scott it would be great if you could push this out to the NVEM boards).
Just as a reference here is a table of the old & new I/O.
I do have one very trivial request though, would it be possible in the next update to number the single digit inputs with a leading zero IE 1 is 01 & so forth. That way they would appear in correct numerical order when looking at them in halshow as well as making the scrips justify nicely ;)
Alex
Done, Remora-nv component updated with %02d formatting and inverted inputs as well.
3 years 6 months ago #268637 by cakeslob
i have convert an old 5Axis mill to LinuxCNC with Remora on EC300 V5
I dont see the jitter exactly, but post more pics of your dental mill pls :)
I was hoping to see the 4th and 5th axis please , pics are pretty elusive online.
3 years 6 months ago #268641 by frayja2002
Can I flash the new beta code to an RT1052 based NVEM?
I took a chance on this & did it anyway.
The spindle output now works correctly.
Here is a list of the inputs I have been able to get to work.
I believe the ETSOP button on the end was working but has now stopped working.
I have not tested any of the outputs.
Alex
3 years 6 months ago #268642 by scotta
This version of the firmware is for the NVEM / EC300 and has the same PWM for the analogue output as the EC500 version. The IO is quite different as you've found.
github.com/scottalford75/Remora-RT1052/b...ora-rt1052-0.0.1.bin
3 years 6 months ago #268645 by frayja2002
Your right...
I flashed this file (remora-rt1052-0.0.1.bin) & it all works.
Here is another list of inputs ( just for correctness)
Alex
3 years 6 months ago #268656 by meister
You can not see the jitter but you can hear it and i can feel it
more pics: www.cnc-aus-holz.at/index.php?thread/310...linux-cnc-steuerung/
Time to create page: 0.599 seconds
