- Thank you received: 489
Yes, this is solved by adding a Pgain setting. The default gain is 1, increasing it to 10 or more will improve the response of the control loop.Is anybody else experiencing slow approach to exact position as well on ec500? (rt1052)
Did you also change the servo frequency in LinuxCNC and inform the Remora component about the different base thread frequency? If not the frequency command calculations are all out and the control loop will be working harder to compensate for the wacky following error. Changing these settings in the firmware must be mirrored on the LinuxCNC side.i get the compilation work on my system
if i reduce the freq of this threads, the jitter is much much better !
#define PRU_BASEFREQ 20000 // PRU Base thread ISR update frequency (hz)
#define PRU_SERVOFREQ 500 // PRU Servo thread ISR update freqency (hz)
Hi Alex, that's it for the NVEM / EC300. The extra outputs are available on the EC500.Just a quick update.
Here is the list of pins i have checked on an RT-1053 based NVEM box.
Scott, could you tell me where (if anywhere) to other output pins go to.
Alex
