- Thank you received: 49
Sounds like some calibration is needed to dial in the step scale.Thanks Scott. It was set to 0, but I changed it to 0.0001 and it seems to work fine now. I have now issue with motor accuracy. The scale is set to 160 and I have set jumpers on JMC ihsv57 motor to 800 steps per rotation so 5mm jog should be exactly one full circle. However its a little less than that. After few 5mm jogs its obvious. So do I have problem with step pulse lenghts?
Yes, I saw that. But where is rxDataCopy being filled with the packet data?source/baseThread.c:
Code:void makeSteps() { static int8_t i; static int32_t stepNow; if (rxDataFlag == 1) { rxDataFlag = 0; memcpy(rxDataCopy.rxBuffer, rxData.rxBuffer, BUFFER_SIZE); } .... but i think its better to move this part to the end of the makeSteps() function
