- Thank you received: 13
Hi Alex, I confirmed the IO on the EC300 and it is correct. So there is a slight difference between the NVEM and EC300. I have updated the source and created individual firmware versions for the NVEM and EC300. Can you please test the NVEM version?Hi Scott
Could I get you to check this
I am running an NVEM RT-1052, when I activate remora.output.00 OUT-2 comes on.
And vice versa. remora.output.01 turns OUT-1.
This seems to be backwards. Is this whats intended?
Alex
