3 years 6 months ago #269339 by Cold Turkey
Unfortunaly i have only an stlink v2 at home
Not to throw a spanner in the works. I I have an ST clone that I have not flashed and I got it to upload the firmware to the EC500 RT-1052. I used pyocd on linux (Buster)
Worth a try if you only have one ST, let us know if it works for you also.
Cheers.
3 years 6 months ago #269344 by scotta
Cheers.
I literally tried this today without success (on Windows). pyOCD first complained about the old firmware version. I did a firmware upgrade to the minimum version number supported, pyOCD would not connect to the ST-link, upgrading to the latest firmware had the same result.
What version of firmware is your ST-Link?
I've got a couple new ST-Links I'll give a try as this would be great if an out of the box solution would reliably work.
3 years 6 months ago #269346 by Cold Turkey
V2.J29.S7
Only tested on Buster
3 years 6 months ago - 3 years 6 months ago #269357 by frayja2002
Hi Scott
I have tested the new firmware & the lights now match the software.
Alex
Last edit: 3 years 6 months ago by frayja2002.
3 years 6 months ago #269360 by Teos81
I'll make a test of the new firmware tonight..
A question.. i use for the test bench a Lenovo T420.. did you have latency problem with notebook?? the first time the machine is started it come out with a latency problem error (sorry i dind't remember the right error.. it was about 2:00 am ) and if i start a gcode program when the F are hight (about 800) it stop with a "following error"..
What could be?? i have made a mix of hal and ini with the example in repo and the one posted by frayja2002
Same gcode executed form the same pc with a windows 10 running and the NVME flashed with original Mach3 fw run well..
P.s. remora and NVME work good over a raspberry PI3B or have latency problem?
3 years 6 months ago #269363 by tommylight
I had 2 of Lenovo T420S, both utterly useless for running LinuxCNC, not even for testing.
Sim works.
The following user(s) said Thank You: Teos81, DarkPhoinix
Time to create page: 0.650 seconds
