- Thank you received: 5
Alex, my bad. When adding the new defines for the NVEM, I neglected to update the code in servoThread.c . Should be good now. SorryHi Scott
I have done some further testing of the new firmware (remora-rt1052-NVEM-0.0.2.bin ) & have found that the various input pins in the MPG area are now not working (that used to work before)
Attached is a list of input pins that were working but are now not working. (written in no particular order)
I have flashed remora-rt1052-0.0.1.bin back into the box & can confirm this.
I was using one of these inputs as an Estop (as per the pic.
Alex
Yes, but the MPG inputs are currently not available. Working on it.Hi Scott, is this working with the new version of the EC500?
Thanks for sharing the latest video, interesting indeed. I'm curious.ok, since I have been wrong before,
I have tested it again
Turn audio on !
You must hear the different
first two moves with original firmware
then two moves with my changes
has anyone ever tested the firmware on a real CNC, not just with free-running motors.
Does anyone want to make a comparison with my changes ?
or have I configured something wrong ?
my ini:
[EMC]
MACHINE = mikro5x
DEBUG = 0
VERSION = 1.1
[DISPLAY]
GLADEVCP = mikro5x.ui
DISPLAY = axis
CYCLE_TIME = 0.100
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
MAX_FEED_OVERRIDE = 10
MAX_SPINDLE_OVERRIDE = 1.0
DEFAULT_LINEAR_VELOCITY = 1200.00
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 1200.00
DEFAULT_ANGULAR_VELOCITY = 36.00
MIN_ANGULAR_VELOCITY = 0
MAX_ANGULAR_VELOCITY = 45.00
PROGRAM_PREFIX = ~/linuxcnc/nc_files
INTRO_TIME = 2
INCREMENTS = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm
DEFAULT_LINEAR_VELOCITY = 0.2
MAX_LINEAR_VELOCITY = 20.0
DEFAULT_ANGULAR_VELOCITY = 20.0
MAX_ANGULAR_VELOCITY = 60
[KINS]
JOINTS = 5
#JOINTS = 4
KINEMATICS =trivkins coordinates=XYZAC
#KINEMATICS =trivkins coordinates=XYZA
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = ~/linuxcnc/subroutines
USER_M_PATH = ~/linuxcnc/m_codes
REMAP = M600 modalgroup=6 argspec=T ngc=toolchange
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 0
SERVO_PERIOD = 1000000
[HAL]
HALFILE = mikro5x.hal
POSTGUI_HALFILE = postgui_call_list.hal
HALUI = halui
[HALUI]
MDI_COMMAND = o<spindle_toggle> call
MDI_COMMAND = o<clamp_toggle> call
[TRAJ]
COORDINATES = X Y Z A C
#COORDINATES = X Y Z A
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 20.0
MAX_ACCELERATION = 500.0
MIN_LIMIT = -150
MAX_LIMIT = 150
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -200.0
MAX_LIMIT = 150.0
MAX_VELOCITY = 20.0
STEPGEN_MAXACCEL = 2000.0
SCALE = 1600.0
FERROR = 1.0
MIN_FERROR = 0.5
HOME_SEARCH_VEL = 20.0
HOME_LATCH_VEL = 3.0
HOME_FINAL_VEL = -20
HOME_IGNORE_LIMITS = YES
HOME_USE_INDEX = NO
HOME_OFFSET = 6.5
HOME = 0.0
HOME_SEQUENCE = 3
my hal:
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt remora-nv
net spindle-enable spindle.0.on => remora.output.01
net digital-out-0 motion.digital-out-00 => remora.output.00
net autotc1 iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net autotc2 iocontrol.0.tool-change => iocontrol.0.tool-changed
net toolprobe <= remora.input.05.not
net toolprobe => motion.probe-input
net slotprobe2 <= remora.input.12
net slotprobe3 <= remora.input.13
net slotprobe4 <= remora.input.14
net user-enable-out <= iocontrol.0.user-enable-out => remora.enable
net user-request-enable <= iocontrol.0.user-request-enable => remora.reset
net remora-status <= remora.status => iocontrol.0.emc-enable-in
addf remora.read servo-thread
addf remora.update-freq servo-thread
addf remora.write servo-thread
# joint 0 setup (X axis)
setp remora.joint.0.scale [JOINT_0]SCALE
setp remora.joint.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net j0pos-cmd joint.0.motor-pos-cmd => remora.joint.0.pos-cmd
net j0pos-fb remora.joint.0.pos-fb => joint.0.motor-pos-fb
net j0enable joint.0.amp-enable-out => remora.joint.0.enable
net home-x <= remora.input.06
net home-x => joint.0.home-sw-in
Thanks,
Olli
EDIT: the firmware-file for testing: github.com/multigcs/Remora-RT1052/tree/l...jitter_test/firmware
