- Thank you received: 280
You don't understand the question.Hey tux, thats not exactly within the scope of the remora project, and more of a general linuxcnc thing.
But since I am also trying to do lathe threading, here is my attempt so far. the encoder/spindle portion is at the bottom
github.com/cakeslob/Remora/blob/nucleo_s...nuc_q/remora-xyz.hal
I try to explain what I did.
Code:Also, please check that you can actually keep up with the encoder pulses per rev. If not then I'll need to look at how we can implement hardware counting which may / may not be available on the pins.
Good to see you are making progress.
Code:Also, please check that you can actually keep up with the encoder pulses per rev. If not then I'll need to look at how we can implement hardware counting which may / may not be available on the pins. I try to explain what I did. ### Test 1 ### In the ec500-rt1052.txt : { "Thread": "Base", "Type": "Encoder", "Comment": "Encoder A-IN9 B-IN10", "PV[i]": 0, "ChA Pin": "P3_19", "ChB Pin": "P3_20" } In the remora-ec500.hal : # Initialize the encoder (spindle) loadrt PRUencoder names=encoder.1 addf PRUencoder.capture-position servo-thread setp encoder.1.position-scale 1200.000000 #6 # connect the hal encoder to linuxcnc net encoder-count remora.PV.0 encoder.1.raw_count net encoder-phaseZ remora.input.11 encoder.1.phase-Z I removed the blocks configured IN9 and IN10 as inputs from ec500-rt1052.txt (I suspect the pins may be defined only once). Works as expected. I ran halmeter, chose encoder.1.position and seen that value changed when encoder turned. I ran halcmd setp encoder.1.index-enable 1 The pin changed state to True, but when encoder changed index output the index-enable changed to False and position changed to zero. ### Test 2 ### In the remora-ec500.hal I removed the line with net encoder-phaseZ remora.input.11 encoder.1.phase-Z In the ec500-rt1052.txt I added this line : "Index Pin": "P3_21" and removed declaration this pin as input. I can change value of encoder.1.position, but encoder Z output does nothing, the encoder.1.index-enable after set is always True, and positon not resets. What I do wrong ?[/i]
Works with line < net encoder-phaseZ remora.input.11 encoder.1.phase-Z > in remora-ec500.hal, but I suspect the PRUencoder component works, not internal EC500 procedure.
[/code][/i][/code]Code:[i][code]You will also need to set the Data Bit in the encoder configuration. [code]{ "Thread": "Base", "Type": "Encoder", "Comment": "Encoder A-IN9 B-IN10", "PV[i]": 0, "ChA Pin": "P3_19", "ChB Pin": "P3_20", "Data Bit": 11, "Index Pin": "P3_21", }[/i]
