3 years 3 months ago - 3 years 3 months ago #274829 by zmrdko
Good to hear Murphy. Did you already try some jogging?
Last edit: 3 years 3 months ago by zmrdko.
3 years 3 months ago #274851 by Murphy
not yet zmrdko maybe tomorrow
3 years 3 months ago - 3 years 3 months ago #274895 by Murphy
Could someone help me with this attribute error. I have flashed the board with the firmware. I can ping the board at 10.10.10.10. when I go and upload the config I get this error below.
I installed tftp. But it's getting an error when I check the status of it
Last edit: 3 years 3 months ago by Murphy.
3 years 3 months ago #274912 by scotta
When you said you installed tftp, what did you do as you should not need a daemon running. You should only need to install TFTPy using pip.
pip install tftpy
3 years 3 months ago - 3 years 3 months ago #274929 by Murphy
Thanks Scott I'll try that. I used "sudo apt-get install tftpd-hpa"
ok so i installed with pip tftpy.Still the same error when I try and upload the config
3 years 3 months ago - 3 years 3 months ago #274950 by Murphy
Ok so I managed to get the config uploaded. when I run linuxcnc I get the following error. I moved the remora-nv.h and remora-nv.c to the Linuxcnc module directory. But still comes up with the same error
Time to create page: 0.165 seconds
