3 years 3 months ago - 3 years 3 months ago #274738 by zmrdko
After converting stlink to RT1052 drive, flash with pyocd command:
forum.linuxcnc.org/media/kunena/attachments/34234/rt1052.PNG
Last edit: 3 years 3 months ago by zmrdko.
3 years 3 months ago - 3 years 3 months ago #274739 by zmrdko
Thanks Scott, it seems to work excellent.
Is there anything particular you’d like me to test?
What is the max step rate EC500 with remora fw can do?
Original firmware for mach3 states 460kHz, but if I recall correctly, with remora firmware it’s different. Dependant on some hardcoded value in firmware.
Im asking because I have set 1000 steps per mm (0.001mm step resolution) and at 40mm/s = 40kHz it’s OK, but at 50mm/s I already get following error.
3 years 3 months ago #274740 by Murphy
Thank you but if no idea what that is. I'm using widows to program it. I quickly Googled pyocd and looks like I have to download a load of stuff for it to work.
3 years 3 months ago #274742 by zmrdko
Try installing pyocd typing into cmd window:
python -m pip install -U pyocd
3 years 3 months ago #274743 by Murphy
3 years 3 months ago #274744 by zmrdko
Maybe try python3 instead of python.
If that does not work, you probably dont have python installed, so you will have to google for guide, how to install python on windows.
Time to create page: 0.186 seconds
