- Thank you received: 56
Are you planning a spindle encoder?This board will be used for an emco PC Turn 55.
Yes eventually. I have a classic ladder file for the 6 position tool changer from a YouTube guy called the feral engineer also.This board will be used for an emco PC Turn 55.
I ask because there is no spindle encoder support in EC500.Yes eventually.
Im not sure, I think there is the ability in Remora for high speed encoder, but it's not yet implemented with this board.Yes eventually.
I seen there is mpg encoder in config, but i cant test anything because I have not machine for test yet.
(There are some reasons that I can't use my lathe. I build a model of lathe, but not finished yet.)
I wonder, is the ability of use mpg-encoder inputs for spindle...
(I need rigid tapping, not simple threading with index only.
