Remora - NVEM / EC300 / EC500
- scotta
- Thank you received: 480
15 Jan 2022 21:04 #231933
by scotta
That would be a neat way of doing it, just no idea at the moment how to implement it. I'm just now getting into how to configure the STM32F207 for ethernet with the LAN8720 PHY that is on the board. On the learning curve at the moment.Hmm think it would be possible to send a config over ethernet?
so you would have a config file located in your linuxcnc config folder then sets the values.
But i think for getting off the ground fast just setting it for most other peoples use case would be better.
I myself do have a few st-links in a drawer somewhere if i needed to make changes.
Whats the part number on the optos?
- cakeslob
- Thank you received: 275
15 Jan 2022 21:18 #231935
by cakeslob
good good, this will work for 3d printers as well, but how would you do this....something like how the 3dprinter configs work (i dont know how that is anyways)? like some kind of hard coded config based on board target, then load to i2c/spi eeprom on initialization, then change config over ethernet/serial? or something like a blank slate config thats configured from hal? sorry, i dont know how it really works just brainstorming.There is an unmarked IC on the board which I'm suspicious is an EEPROM.
- ALittleOffTheRails
- Visitor
15 Jan 2022 23:04 #231961
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I'll keep watch of this.
If I can find one at the right price I'll grab one.
- scotta
15 Jan 2022 23:24 #231966
by scotta
The MPG with TFT display will be another project... need to reverse engineer the serial comms protocol and build that as a Remora module.
I was pretty happy with the price on Aliexpress. Got the 6 axes NVEM with the NVMPG for just under $200 AUD delivered with taxes etc.I'll keep watch of this.
- scotta
15 Jan 2022 23:25 - 15 Jan 2022 23:26 #231968
by scotta
Last edit: 15 Jan 2022 23:26 by scotta.
- scotta
15 Jan 2022 23:28 #231969
by scotta
- scotta
15 Jan 2022 23:38 #231970
by scotta
I'm contemplating doing this version of Remora in STM32CubeIDE rather than Mbed Studio as this will be specific to the NVEM board with the STM32F207.
Thoughts?
Thoughts?
The following user(s) said Thank You: tuzki
- scotta
16 Jan 2022 00:04 #231973
by scotta
The following user(s) said Thank You: phillc54, tommylight, tuzki, AlessandroEmm, ALittleOffTheRails
- Visitor
16 Jan 2022 00:17 - 16 Jan 2022 00:33 #231976
Like this ?
www.aliexpress.com/item/1005002272437121...4c56a860dd7b07510627
I would only want 3 axis for my lathe.
If you were ever to design your own hardware I'd be happy to help out with a few beer tokens thrown your way and with testing could even have a go at pcb design, basically whatever help.....just a thought.
Last edit: 16 Jan 2022 00:33 by ALittleOffTheRails.
- scotta
19 Jan 2022 06:20 #232402
by scotta
The following user(s) said Thank You: arvidb, tommylight, Pro_El, FCS Industrial, pinder, tuzki, AlessandroEmm, ALittleOffTheRails
Time to create page: 1.058 seconds
