Remora - NVEM / EC300 / EC500
30 Mar 2022 19:46 #238810 by royka
Yes you could first setup your ini file, then edit. You will not find anything in linuxcnc about remora except in your ini and hal file. Please watch this YouTube video about how to download from GitHub, because you shouldn't have html code if you did it right:
The following user(s) said Thank You: Domi
31 Mar 2022 02:57 #238863 by spdbmp927
Replied by spdbmp927 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I don't see Remor in Linuxcnc. It saved as: cp remora-eth.so / usr / lib / linuxcnc / modules
Where and how should it be placed? How did you download hal? Downloaded as a link to github.com/scottalford75/Remora/blob/feature/ethernet/LinuxCNC/ConfigSamples/remora-eth/remora-eth.hal
Domi, thats all there is to it. The .so is the compiled file hal uses and modules is where it belongs, so you're good.
31 Mar 2022 03:14 #238865 by spdbmp927
Hello all,
I have had an NVEM board for about a year with plans to use it with MACH3 on a Bridgeport mill conversion. I recently started on the conversion, and came across this and couldn't turn it down. I also have a couple RPis laying around. Today I loaded a RPi with 64bit buster and built LinuxCNC for it. If this wasn't challenging enough my HDMI cable broke so I did most of it through SSH. I am now getting ready to reprogram the STM32 so i can do some wiring and testing.
Scott, I tried but my mysterious DIP8 is completely blank, not a single symbol.
31 Mar 2022 05:55 #238869 by Domi
Ok. I managed to download and install it. I rewrote Hal as I wrote royka. I don't understand what you mean (my ini file). Royka: In which file did you overwrite the output for the spindle? Now I stopped setting up a static IP. I tried different ways according to the instructions from the web, but without success. Another question: what then? How did you install mymill for remoru? Via Applications-Linuxcnc (axis) or via some wizard? For example, for a mesa card? Because only there it is to write the IP address. I guess I really should have bought a Mesa card. But I liked this board (simple, described inputs and outputs, communication speed, ethernet and of course the price). And I like to try new things. And when I came across this thread, it seemed easy to me. But it is not so. At least not for me.
31 Mar 2022 06:01 #238871 by Domi
And I don't understand why it's not all as easy as in the deebian wheezy I used on the LPT port before. Now I have installed Livecd LinuxCNC Deb 10 Buster and the terminals are missing some components like wget and so on.
31 Mar 2022 10:39 - 31 Mar 2022 10:54 #238888 by royka
Your ini file is the configuration file. You can find everything on this forum, wiki, google, youtube. The things you're asking is mostly the beginning basic, start reading please. You say you like to try new things, but then you ask why it's not as easy as it was with the lpt port....
linuxcnc.org/docs/html/common/linux-faq.html#faq:terminal
linuxcnc.org/docs/html/getting-started/running-linuxcnc.html
linuxcnc.org/docs/html/examples/spindle.html
When you created a configuration with the wizard it creates a shortcut on the desktop. You could right click on it and choose (something like) "Edit launcher" and you will see which ini file it loads. In the folder of that ini file you have to copy the hal file to. Then in the ini file type the name of that hal file (instead of the default one).
In short with the launcher, you start LinuxCNC with the configuration file, so LinuxCNC knows which configuration to load.
In your configuration file (.ini) you can tell which hal file to load.
The spindle configuration in my post probably needs to be inverted, in the manual of Remora you could find how to. When I'm ready I will post my config
Last edit: 31 Mar 2022 10:54 by royka.
01 Apr 2022 01:31 - 01 Apr 2022 01:34 #238964 by spdbmp927
 Before I flashed the NVEM with the Remora firmware I created an image of the stock software also, so I have one if its needed. I did buy my board about a year ago and it says NVEMV2 on it so i believe it is a version 2 board, and I don't know how different they are.
I do have the mystery chip, although it is rotated from Scott's board and the power and ground pins are switched. The three connected pins are the same as Scott's diagram. Scott, when you tested the PA_3 pin do you remember if the ST-Link was connected? To be clear by connected I mean having pushed the "connect" button on the programmer, and disconnected meaning plugged in and powered up, but without connecting, or having pushed "disconnect" on the programmer. While the ST-Link was connected PA_3 stayed near ground, but when I disconnected the ST-Link I discovered a 3.75 Mhz square wave on the PA_3 pin. As soon as you connect the programmer the square wave stops, and it restarts on disconnect.
After the disconnect button is pushed or the device is initially powered on the PA_5 pin seems to go low for a short pulse, wait ~0.3 seconds, then host short burst of communication. The PA_4 pin goes low for this brief pause, and then returns high. This initial pulse (before the apparent communication) is when the PA_3 pin starts the 3.75 Mhz signal.
It appears that pin 5 is a single wire communication line. I'm not sure what it is but it appears to be high or low for multiples of 100 microseconds.
When I flashed the Remora firmware the signals all stopped. PA_4 and PA_5 remain high, and PA_3 remains low so whatever it is it's at least initiated by the processor. I'm not sure what to make of all this, but hopefully this will help.
Last edit: 01 Apr 2022 01:34 by spdbmp927. Reason: fixed a typo
01 Apr 2022 09:29 #238976 by Domi
Hello. So I seem to have done everything I had. Well, after starting, I get an error :
01 Apr 2022 19:13 #239009 by Domi
I also adjusted the lines 12,13,14 according to royk but it doesn't work. Then I used the original but it still doesn't work. It gives an error. Can't advise where to bounce?
01 Apr 2022 20:39 #239014 by royka
Read, it says unknown command "remora.SPI-enable". So you didn't change that line
Time to create page: 0.322 seconds
