Remora - NVEM / EC300 / EC500
06 Apr 2022 15:43 #239449 by Domi
So far, I only use remora-eth.hal
06 Apr 2022 23:43 #239480 by cakeslob
ok domi, for simplicity, lets just use remora-eth.hal
I dont have a nvem board but Ill see what I can do, so I am learning this along side you. I dont know if there was a docs I missed for this board specifically, and Im also not very good with hal.
First, lets see what/where the inputs are. google image of the board and a quick check of the firmware shows the inputs are numbered starting from STOP
// INPUTS
    Module* STOP = new DigitalPin(*ptrInputs, 0, "PD_8", 0, true, NONE);
    servoThread->registerModule(STOP);
    Module* PROBE = new DigitalPin(*ptrInputs, 0, "PD_9", 1, true, NONE);
    servoThread->registerModule(PROBE);
    Module* INP3 = new DigitalPin(*ptrInputs, 0, "PD_10", 2, true, NONE);
    servoThread->registerModule(INP3);
    Module* INP4 = new DigitalPin(*ptrInputs, 0, "PD_11", 3, true, NONE);
    servoThread->registerModule(INP4);
    Module* INP5 = new DigitalPin(*ptrInputs, 0, "PD_14", 4, true, NONE);
    servoThread->registerModule(INP5);
    Module* INP6 = new DigitalPin(*ptrInputs, 0, "PD_15", 5, true, NONE);
    servoThread->registerModule(INP6);
    Module* INP7 = new DigitalPin(*ptrInputs, 0, "PC_6", 6, true, NONE);
    servoThread->registerModule(INP7);
    Module* INP8 = new DigitalPin(*ptrInputs, 0, "PC_7", 7, true, NONE);
    servoThread->registerModule(INP8);
    Module* INP9 = new DigitalPin(*ptrInputs, 0, "PC_8", 8, true, NONE);
    servoThread->registerModule(INP9);
    Module* INP10 = new DigitalPin(*ptrInputs, 0, "PC_9", 9, true, NONE);
    servoThread->registerModule(INP10);
    Module* INP11 = new DigitalPin(*ptrInputs, 0, "PA_11", 10, true, NONE);
    servoThread->registerModule(INP11);
    Module* INP12 = new DigitalPin(*ptrInputs, 0, "PA_12", 11, true, NONE);
    servoThread->registerModule(INP12);
    Module* SRO = new DigitalPin(*ptrInputs, 0, "PB_14", 12, true, NONE);
    servoThread->registerModule(SRO);
    Module* SJR = new DigitalPin(*ptrInputs, 0, "PB_15", 13, true, NONE);
    servoThread->registerModule(SJR);
    Module* x100 = new DigitalPin(*ptrInputs, 0, "PA_15", 14, true, NONE);
    servoThread->registerModule(x100);
    Module* x10 = new DigitalPin(*ptrInputs, 0, "PC_10", 15, true, NONE);
    servoThread->registerModule(x10);
    Module* x1 = new DigitalPin(*ptrInputs, 0, "PC_11", 16, true, NONE);
    servoThread->registerModule(x1);
    Module* ESTOP = new DigitalPin(*ptrInputs, 0, "PC_12", 17, true, NONE);
    servoThread->registerModule(ESTOP);
    Module* Xin = new DigitalPin(*ptrInputs, 0, "PD_7", 18, true, NONE);
    servoThread->registerModule(Xin);
    Module* Yin = new DigitalPin(*ptrInputs, 0, "PD_4", 19, true, NONE);
    servoThread->registerModule(Yin);
    Module* Zin = new DigitalPin(*ptrInputs, 0, "PD_3", 20, true, NONE);
    servoThread->registerModule(Zin);
    Module* Ain = new DigitalPin(*ptrInputs, 0, "PD_2", 21, true, NONE);
    servoThread->registerModule(Ain);
    Module* Bin = new DigitalPin(*ptrInputs, 0, "PD_1", 22, true, NONE);
    servoThread->registerModule(Bin);
    Module* Cin = new DigitalPin(*ptrInputs, 0, "PD_0", 23, true, NONE);
    servoThread->registerModule(Cin);
    Module* WHA = new DigitalPin(*ptrInputs, 0, "PB_7", 24, false, NONE);
    servoThread->registerModule(WHA);
    Module* WHB = new DigitalPin(*ptrInputs, 0, "PB_6", 25, false, NONE);
    servoThread->registerModule(WHB);
    Module* INDEX = new DigitalPin(*ptrInputs, 0, "PC_15", 25, false, NONE);
    servoThread->registerModule(INDEX);
" Module* PROBE = new DigitalPin(*ptrInputs, 0, "PD_9", 1,"
Ok, so "Module* PROBE" is probably the name on the board , and Im pretty sure the number to the right is the remora input pin number "1"
so in hal, the PROBE port is hal pin remora.input.1, now we need to connect them within/to linuxcnc so linuxcnc knows what goes where.
linuxcnc.org/docs/devel/html/hal/intro.html
remora-docs.readthedocs.io/en/latest/sof...dstops-home-switches
linuxcnc.org/docs/devel/html/man/man9/mo....9.html#JOINT%20PINS
linuxcnc.org/docs/devel/html/man/man9/mo...9.html#MOTION%20PINS
We know now which pin is where on the board, now to connect them to linuxcnc, using the examples from above, and if probe is remora.input1, we then connect it to linuxcnc pin motion.probe-input, and we do the same for limits. im pretty sure this is safe, so add it to your remora eth.hal and see what happens
net Probe-IN    remora.input.1  => motion.probe-input
net X-min       remora.input.2  => joint.0.home-sw-in joint.0.neg-lim-sw-in
net Y-min       remora.input.3  => joint.1.home-sw-in joint.1.neg-lim-sw-in
net Z-min       remora.input.4  => joint.2.home-sw-in joint.2.neg-lim-sw-in
Check out some more of the configuration and hal section of the docs, because if you understand some of the basic concepts, it will make this next set of instructions easier
linuxcnc.org/docs/
The following user(s) said Thank You: Domi
07 Apr 2022 00:09 #239483 by cakeslob
If you are following along with the previous post and are understanding some of the basics of hal and what it is, we can streamline your configuration process by using the stepconf. stepconf is used for making easy parallel port configurations. Different hardware, but the core concepts are the same, being we need to link hardware pins to software pins
linuxcnc.org/docs/stable/html/config/stepconf.html
If you generate a file for the parallel port, you can open up the hal file it created, and use that as reference. for example
net X-neg-limit parport.0.pin-11-in => joint.0.neg-lim-sw-in
you would replace the hal pin for parport, with the pin for remora hal. and would become this.
net X-neg-limit remora.input.2 => joint.0.neg-lim-sw-in
This is all probably more involved than you were expecting, but remora for nvem is pretty new
  • scotta
  • Platinum Member
  • Platinum Member
08 Apr 2022 03:42 - 08 Apr 2022 03:44 #239615 by scotta
Thanks cakeslob for helping out. I've started on an "example" 3 axis config which hopefully get people going quicker. As we add functionality I'll update the example.
I've remapped the IO and updated the bin file in the repo. The reason for remapping is to align with the physical layout of the controller.
The example has been aligned to this IO mapping: github.com/scottalford75/Remora/tree/fea...igSamples/remora-eth
Last edit: 08 Apr 2022 03:44 by scotta.
09 Apr 2022 07:01 #239714 by Domi
Hi cakeslob: I tried the limit switches according to my instructions. I see them but it shows them on and when I attach the metal so off. All input pins on NVEM are FALSE without connection. I read and tried a lot. But I can't reverse it. I use PNP NC and it looks like the signal is the opposite. I exchanged arrows. He tried data in and out and other different things according to the instructions. I also read the forum but nothing helped. Won't it be that NVEM has Unconnected pins like FALSE? I also tried to use the procedure for realtime but without point. Well thank you.
09 Apr 2022 08:15 #239715 by Domi
09 Apr 2022 12:22 #239729 by Domi
scotta: now I have to download the file Remora-NVEM bin to NVEM again via STlink? Or some other files? And where to place the modified remora-eth file? Or will I use only hal and others from the remora-eth file? and what to do with the file py? Well thank you
09 Apr 2022 16:13 #239747 by cakeslob
Ok, thats good domi, if you can see the pins changing state that is progress. If you want to use the new sample config posted by scott, you will need to load the new firmware bin file to the nvem with st link like you did before. the new firmware changes the pin layout , so the new firmware matches the new hal. With the new firmware, you need to change the remo-eth.hal, but to keep things simple , just download the whole folder and keep them both in separate config folders.
The upload config .py file is something new that I am excited for, dont know how it works yet.
Back to the limit switch. if your limit switches change state, that is good. Now we just need to invert the state. Try adding this to the hal part
net X-neg-limit remora.input.2 => joint.0.neg-lim-sw-in-not
09 Apr 2022 16:57 #239752 by Domi
I've tried that before : does not exist
09 Apr 2022 21:23 - 09 Apr 2022 21:26 #239774 by Domi
So I run the new firmware bin and hal. I didn't move on. Sensors do the same.I can't turn their signal to true / false
Last edit: 09 Apr 2022 21:26 by Domi.
Time to create page: 0.586 seconds
