Potential All-in-One Single Board Computers
4 years 1 month ago #251946 by tommylight
Replied by tommylight on topic Potential All-in-One Single Board Computers
Manta M4P/M8P Control Board with CB1/CM4
biqu.equipment/products/manta-m4p-m8p
CB1 Allwinner H616 Linux control board for $27 that plugs into a 4 or 8 axis STM32 Remora controller board Manta 4 ($40) or Manta 8 ($98)
That one is very nice, saves a lot of wiring ... and things that could go wrong! :)
4 years 1 month ago #251955 by tommylight
Made this sticky due to the chip shortage.
The following user(s) said Thank You: Bari
4 years 1 month ago - 4 years 1 month ago #251959 by cakeslob
Replied by cakeslob on topic Potential All-in-One Single Board Computers
No, I didnt buy a manta, just cb1. I was less enthusiastic about it, but you guys got me interested now.
heres my info dump
notes: i dont know if the remora linuxcnc component will work with non rpi soc's
Btt manta M8P -Hardware wise it looks usable, they even put the spi pins right beside the rpi header. has mcu sd card also. uses cm4 footprint -mcu is stm32g0b1 ,currently untested, mbed supports a version of this chip so maybe -needs jumpers to spi
Fysetc Cheeta mix -hardware wise it looks fine, similar to their other boards, cm4 spi broken out on rpi header, uses cm4 footprint -mcu is stm32f401. should be fine, but i havent been able to get fysetc boards to work yet with remora wither their sd/spi setup. -needs jumpers from spi to spi
MKS SKIPR - hardware wise spi is broken out and there are 2 sd slots. has rk3328 -MCU is stm32f407, so well supported for remora. could work pretty easy but im having issues with another mks board re: sd card - hardware wise i like this one the best -needs jumpers
www.aliexpress.com/item/1005004509354702...00029429564667%21rec
Mellow Gemini v2 -hardware wise I see an SOC spi broken out, so it looks usable. it looks like they might even have a direct line from mcu spi2 to soc spi0, via some switches I think they use this for automatic firmware updates, but we can use this for remora -MCU is stm32f405, so could probably work. -no wires needed possibly
Honorable mention goes to the
Fysetc spider king. this one is pretty cool. -pretty good hardware, with a 26 pin rpi compatible pinout for connecting to uart and spi. -MCU is a socketed replaceable MCU, finally someone gets it. so far only the stm32f407 but others to come.
www.aliexpress.com/item/1005004635283874...000029921056695%21sh [/code]
Last edit: 4 years 1 month ago by cakeslob. Reason: this fucking editor
4 years 1 month ago #251961 by cakeslob
MKS also has a rockchip based SBC with just spi and uart broken out for a reasonable price
www.aliexpress.com/item/1005004417871231...00029113611340%21rec
also unrelated, but this thing is pretty slick from BTT, the Raspberry Pad 5,
its a RPI CM4 dsi screen
One of my setups is cm4 + pad5 + skr2,
sans powersupply, the whole controller is 130mm x 85mm
www.aliexpress.com/item/1005003970088375...000027611174862%21sh
4 years 1 month ago - 4 years 1 month ago #252065 by Bari
Last edit: 4 years 1 month ago by Bari.
The following user(s) said Thank You: tommylight, MX_Master
4 years 1 month ago #252691 by tommylight
Link to aliexpress in description
Time to create page: 0.135 seconds
