Ehternet motion card
- CNC123
So what kind ends sensors i will need on motion card Mesa7i96S
NPN OR PNP
And NC or NO?
Hmm?
11 isolated inputs provided for general control use including limit switch and control panel inputs. Inputs operate with 5V to 36V DC and can have a positive or negative common for sourcing or sinking input applications
So you can use either NPN (positive common) or PNP (negative common) depending on which you choose.
NO or NC depends on the target. You want a power failure or cable break in the sensor to look like an end stop.
One subtlety that it is easy to miss with proximity sensors is that inductive sesors have two types. The shielded ones can be identified by the outher threaded sleeve coming all the way to the end. Those will work if buried in the metal of a machine axis. The other type, whee you can see the plastic end, will detect the hole that they are in if they are below the surface.
- CNC123
Len len obrazovku a toto
a.aliexpress.com/_mMiQqlK
je všetko alebo potrebujem potrebovať viac?
Hm
You could look at the Pi400, they seem to be available and you get a keyboard included.
- CNC123
Hmm
- CNC123
With rasberry pi4 or 400 or something better???
www.mini-itx.com/~J3355B-ITX might be worth considering?So Mesa 7i96S with who will be works
- CNC123
And i will be need something more for this computer? Or no
Hmm
- CNC123
To answer the first question, yes, the PC motherboard that I linked will need RAM, a PSU and storage. For PSU a PicoPSU (from the same site) is about £20 and RAM is another £20.
For storage you probably need an SATA drive, I have had decent success with things like www.ebay.co.uk/itm/293724488453 though I think that these are now rather outmoded and there may be more cost effective options on a GB/$£€ measure.
