Parallel Port Tester
  • BigJohnT
  • BigJohnT's Avatar Topic Author
  • Administrator
  • Administrator
18 Oct 2010 19:54 - 18 Oct 2010 19:55 #4743 by BigJohnT
Parallel Port Tester was created by BigJohnT
This is a little parallel port tester done with pyVCP.
To run this place both files in the same directory and open a terminal window and use the command
halrun -I -f ptest.hal
You can push the output buttons and change the state of each output. When you toggle an input it shows up on the screen.
Attachment ptest.zip not found
Enjoy
Last edit: 18 Oct 2010 19:55 by BigJohnT.
The following user(s) said Thank You: seuchato, captain chaos
07 Jun 2011 17:16 #10359 by TarHeelTom
Replied by TarHeelTom on topic Re:Parallel Port Tester
<snip>
Enjoy
John,
What is the switch immediately following "halrun" in the above code sequence?
Tom
  • BigJohnT
  • Administrator
  • Administrator
07 Jun 2011 17:22 #10360 by BigJohnT
07 Jun 2011 17:24 #10361 by TarHeelTom
BigJohnT wrote:
Tom,
www.linuxcnc.org/docview/html/man/man1/halrun.1.html
Tom
23 Aug 2012 12:09 #23575 by Tonico
Replied by Tonico on topic Re:Parallel Port Tester
I am trying to run this test. First can it be run with nothing connected to the parallel port? If so this is what happens:
When I run halrun -I -f ptest.hal I get " Waiting for component 'PortTest' to become ready" a bunch of dots and than halcmd: I also get a new blank window called PortTest., eventually every thing seems to time out and I get back the normal prompt and the blank window closes.
This may wll be something that I am doing wrong due to my ignorance of Linux.
Any help wpould be appreciated
TIA
Tony.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
23 Aug 2012 20:26 - 24 Aug 2012 17:26 #23589 by Todd Zuercher
Replied by Todd Zuercher on topic Re:Parallel Port Tester
Yes it works with nothing pugged into the port. You have to be sure that the port adress in the 1st line of the Hal file is the same as the port you are testing.
I would use it (a slightly modified version) to test if certain ports would work work in X-mode. I would start the test then probe holes with a resistor to see if the circles changed color.
Last edit: 24 Aug 2012 17:26 by Todd Zuercher. Reason: The file I attached was bad.
24 Aug 2012 13:22 #23623 by Tonico
Thanks for the reply. Unfortunately it did not help. The address in the Hal file is in fact the same as the port (onboard parallel port)
Is there anything that I need to do or set up BEFORE I run the test?
TIA
Tony
  • BigJohnT
  • Administrator
  • Administrator
24 Aug 2012 16:59 - 24 Aug 2012 17:00 #23634 by BigJohnT
Replied by BigJohnT on topic Re:Parallel Port Tester
Are you running this on a computer with LinuxCNC installed via the LiveCD?
It should just work...
Are both files in the same directory?
Did you open the files with a windoze editor that might have tacked on some funny stuff to the end of each line?
Last edit: 24 Aug 2012 17:00 by BigJohnT.
  • Todd Zuercher
  • Platinum Member
  • Platinum Member
24 Aug 2012 17:44 #23639 by Todd Zuercher
Here's the corrected X-mode ptest files. I fell pray to windows scrambling the xml file when I posted from my windows machine.
File Name: ptest-b452...b853.zip
File Size:1 KB
24 Aug 2012 20:13 #23641 by Tonico
Yes it was installed from a Live CD 8.04 -
Yes both files in the same directory
Downloaded directly to the Linux box and used "text editor" to verify the port address.
Tony
Time to create page: 0.271 seconds
