- Thank you received: 234
ODroid as raplacement for Raspberry Pi
3 years 8 months ago #264998
by Bari
Replied by Bari on topic ODroid as raplacement for Raspberry Pi
> You have to be careful when doing stress testing. The test needs to look like the load you expect to have for the numbers to be relevant.
We have little control over how the applications and drivers are developed so we look for worst case in testing. If you wish to gamble on what the lowest latency might be to run a base thread for software stepping on your hobby machine that is up to you. There is no latency police enforcing anything involved here
If any of the ODroids end up testing reliable enough to use in production machines they will be be running servo threads anyway with external FPGAs for steppers, encoders and servos.
3 years 8 months ago #265025
You see ignorant comments like this one whxih was well retorted!
forum.armbian.com/topic/13250-preempt-rt...omment&comment=96666
Some people have no idea. 20 ms is real time what crap!
Nice reply
With the Odroid N2, you get a 6 core CPU (4 BIG, 2 little for power saving)
I think if you look at kernel development both normal and real time, there is a lot of effort happening to support the ARM environment, some of it is directed at the N2. You can't use this stuff on the Buster 4.x kernel......
Replied by rodw on topic ODroid as raplacement for Raspberry Pi
I don't think there is any doubt Odroid's are reliable as I've used several of their x86 devices and they work fine once you get the NIC drivers installed. (Hint: the 5.10 kernel - Bullseye and above includes the driver). One of them runs Bullseye and Ethercat. Its just their user base is not really worried about Real time so we are not catered for.If any of the ODroids end up testing reliable enough to use in production machines they will be be running servo threads anyway with external FPGAs for steppers, encoders and servos.
Curious as to why one wants to apply the patches for preempt-rt in the first place? Do you have a reason/application that would benefit? Most times, one can see an overall decrease in application performance, and to take advantage of preempt-rt, the application must call pthreads in a very specific way - which means that many times, the app must also be rebuilt.
My reason for asking - if preempt-rt was so awesome, it would already be in the upstream linux kernel mainline and not require the patch. Avoiding politics around preempt-rt - many of the benefits here can be done without the patches, by selecting an appropriate scheduler
Nice reply
Curious as to why you waste your time if you don't want to help?
- alangibson
- Thank you received: 36
3 years 8 months ago #265119
by alangibson
Replied by alangibson on topic ODroid as raplacement for Raspberry Pi
I've been trying to get the LinuxCNC UI running since yesterday with no luck.
HAL threads flatly refuse to run on tobetter's 5.15 kernel. All of the userland tools like halcmd work fine though.
They will run on the 5.10 kernel, but none of the various UIs will load due to some error that mentions panfrost. So I'm guessing there's a graphics driver issue.
Next I'm going to take a step back and use tobetter's old 5.10 RT kernel on Ubuntu 20.10 like in this thread:
forum.odroid.com/viewtopic.php?t=41129
I'm also going to post my findings to the Odroid forum at some point.
3 years 8 months ago #265143
Alan, I Installed your kernel to an eMMC drive but it booted in text mode to a command prompt
I tried tasksel but it failed so I unstalled ubunto mate. But It reverted to a non RT kernel somehow.
But the CNC folder existed in the menus. I guess I should have just run xstart.
James has a good scripted version of Linuxcnc on the 5.10 kernel which might save you some time.
github.com/joco-nz/lcnc-bullseye-installer
- alangibson
3 years 8 months ago #265214
by alangibson
I should have included that in the script. I'm going to run in kiosk mode, so I didn't bother installing a desktop
Thanks. I've mostly been doing this as a learning experience, so I started from scratch. However now I'm running up against issues with tobetter's kernels which are above my pay grade to fix. Now I'm moving on from building it myself.
Speaking of which, I've just gotten the LinuxCNC simulator working on Debian Bullseye with realtime 6.0 kernel provided by meveric on the Odroid forums. Latency numbers look similar to the image and kernel from tobetter.
The conversation about it is here:
forum.odroid.com/viewtopic.php?p=365377#p365377
I've updated my repo that I linked to with instructions if anyone else is interested.
3 years 8 months ago #265216
Alan, Great work. My Armbian mentor Going has said to me tonight
We are working with the 6.2 kernel. I think I'll have to send him a N2+ if he nails this. If we get a RT branch, we can work on a linuxcnc branch
He's been amazing helping me. He was a bit rusty as he's been working on Xeomai 4 and had not played with PREEMPT_RT since 2015Good afternoon, Rod. I found the problem. It is located in the kernel scheduler. Either the RT patch breaks something there or the developers haven't finished something. I had to disable some items in the kernel configuration file and now it works on my banana device. The tests work and show the expected results.
Now I'm launching an assembly for your device.
Time to create page: 0.157 seconds
