Hmm ChatGPT came up with this
Certainly! Here is an example of a timer interrupt service routine for an ARM Cortex-A CPU that toggles a GPIO pin at a frequency controlled by a variable that can be changed in real-time:
#include <stdint.h>
#include "arm_gic.h" // Include the appropriate GIC (Generic Interrupt Controller) file for your specific ARM CPU
#define GPIO_PIN_NUM 10 // The number of the GPIO pin to toggle
#define TIMER_INTERRUPT_ID 30 // The ID of the timer interrupt to use
#define CLOCK_FREQ_MHZ 100 // The frequency of the clock in MHz
volatile uint32_t tick_count = 0;
volatile uint32_t frequency_mhz = 1; // The frequency to toggle the GPIO pin in MHz
void timer_interrupt_handler(void) {
tick_count++; // Increment tick count on every timer interrupt
// Toggle the GPIO pin based on the frequency setting
if (tick_count % (CLOCK_FREQ_MHZ / frequency_mhz) == 0) {
toggle_gpio_pin(GPIO_PIN_NUM);
// Clear the interrupt flag in the GIC
arm_gic_clear_interrupt(TIMER_INTERRUPT_ID);
void set_frequency_mhz(uint32_t freq_mhz) {
frequency_mhz = freq_mhz;
int main(void) {
// Initialize system clock and peripherals
// Note: the exact initialization code will depend on your specific ARM CPU and board
// Configure the GPIO pin as an output
configure_gpio_pin_output(GPIO_PIN_NUM);
// Configure the timer interrupt
arm_gic_configure_interrupt(TIMER_INTERRUPT_ID, ARM_GIC_PRIORITY_MEDIUM, timer_interrupt_handler);
// Enable the timer interrupt
arm_gic_enable_interrupt(TIMER_INTERRUPT_ID);
while (1) {
// Your main program code here
// Call set_frequency_mhz to change the frequency setting in real-time
In this example, we assume that there are functions toggle_gpio_pin and configure_gpio_pin_output available to toggle the GPIO pin and configure it as an output. The frequency_mhz variable is used to set the frequency of the GPIO pin toggle operation. The timer_interrupt_handler function is called on every timer interrupt and toggles the GPIO pin at the specified frequency. The set_frequency_mhz function can be called from the main program to change the frequency setting in real-time. Note that we assume that CLOCK_FREQ_MHZ is a constant representing the frequency of the clock in MHz.
Note that this is just an example and may need to be modified to work with the specific ARM CPU and peripherals you are using. The exact initialization code and the implementation of the toggle_gpio_pin and configure_gpio_pin_output functions will depend on your specific ARM CPU and board.
Not bad...
