- Hardware & Machines
- Computers and Hardware
- Does anyone have an RTAI kernel and a version 2.9 built on it?
- Dalbjerg
07 Mar 2023 20:48 #266058
by Dalbjerg
Does anyone have an RTAI kernel and a version 2.9 built on it? was created by Dalbjerg
Hi I have an older version 2.8~pre on my router. After moving and unpacking for 3 years, I have assembled it again. New I can see that version 2.9 is what everyone is counting on. Among other things, there are options for a better user interface. But I run it all on printer ports, so an RTAI version is needed. I have tried unsuccessfully to build a version (5.3.3) but it won't work for me. Has anyone made one like this? There is a good one for 2.8 (linuxcnc.org/docs/2.8/html/getting-start...#cha:Installing-RTAI)
But I think there are more of us who could use a version 2.9
Sincerely, Bo
Sincerely, Bo
- Thank you received: 4648
07 Mar 2023 21:50 #266075
Replied by andypugh on topic Does anyone have an RTAI kernel and a version 2.9 built on it?
RTAI support was removed from 2.9.
Putting it back is on my list of things to do.
- Dalbjerg
08 Mar 2023 14:51 #266118
by Dalbjerg
Replied by Dalbjerg on topic Does anyone have an RTAI kernel and a version 2.9 built on it?
Ok, I'm glad that you still think of us who use the parallel port as communication to our router.
But just take your time.
I appreciate all of you who contribute to the development of LINUXCNC.
Sincerely, Bo
Sincerely, Bo
The following user(s) said Thank You: flyingbrick
- whatswithhumans
- Visitor
08 Dec 2023 04:52 #287502
by whatswithhumans
Replied by whatswithhumans on topic Does anyone have an RTAI kernel and a version 2.9 built on it?
BUMP!
I have 3 Dell Optiplex 980's, that could get 10k-15k Latency with 2.7 RTAI.
Switched to 2.9 and its like 40k-50k, Killing my rapids...
Thank you
-Regards
Thank you
-Regards
08 Dec 2023 10:07 #287511
The 2.9.1 release includes a version for RTAI.
If you are on Buster with an RTAI kernel then it should just be a matter of updating the apt sources to 2.9-rt and allowing the update to happen.
linuxcnc.org/docs/stable/html/getting-st...dating-linuxcnc.html
If you are not on Buster then install Bookworm, install the RTAI kernel and then install the 2.9-rt version of LinuxCNC.
- gaston48
- Thank you received: 5
12 Dec 2023 21:09 #287976
by gaston48
Replied by gaston48 on topic Does anyone have an RTAI kernel and a version 2.9 built on it?
Hello Andy
it seems that linuxcnc-dev (for rtai) as well as the documentation is not
present in the package?
13 Dec 2023 00:25 - 13 Dec 2023 00:25 #287990
Should be fixed now. (at least for bookworm)
Last edit: 13 Dec 2023 00:25 by andypugh.
- gaston48
13 Dec 2023 13:41 #288032
by gaston48
Thanks Andy,
For the moment it is an update on Buster to 2.8.4 rtai
My configuration works, I finally have enough HAL memory.
Everything is working, remains an "invalid parameter message"
with one of my components :
and the parasitic cursors of my OLED is persistent now
13 Dec 2023 14:54 #288046
Could you not use the "message" HAL component?
linuxcnc.org/docs/stable/html/man/man9/message.9.html
- gaston48
13 Dec 2023 17:19 #288057
by gaston48
Sorry, I don't remember why I didn't use the original component?
the exact error message is "Invalid module format"
message.ko compiled under 2.8.4 but not tested by running linuxcnc.
