Will Raspberry Pi4 work with Mesa 7i80HD via Ethernet
- Thank you received: 4151
06 Apr 2023 10:18 #268403
Replied by rodw on topic Will Raspberry Pi4 work with Mesa 7i80HD via Ethernet
If you have the Pi4B, you can try this method that uses debian all the way.. I worked this out 12 months or so ago but have not played with a Pi since!
docs.google.com/document/d/1S0K-UBlXnsYC...b_0/edit?usp=sharing
06 Apr 2023 10:20 - 06 Apr 2023 10:21 #268405
Forgot to mention that if the pi does not work out Its an ideal platform for Home assistant. I'm sure it could be useful on a boat too. Mine uses a PoE Hat so the only connection is the ethernet cable to a PoE switch.
Last edit: 06 Apr 2023 10:21 by rodw.
