2 years 5 months ago #300957 by Zayoo
I have a raspberry pi5 and this is the code of how I started the SPI communication of the RPI5 - TangNano9K. (Not yet machine tested)
OS:  In /boot/broadcom/config.txt check is SPI is enabled (reboot if not)
# uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
In /dev/
Check do you have listed spidev0.0, should be!
In RIO.h define:
#define TRANSPORT_SPI5
In RIO C add lines:
#ifdef TRANSPORT_SPI5
#include <linux/spi/spidev.h>
#include <sys/ioctl.h>
#endif
*                STRUCTURES AND GLOBAL VARIABLES                       *
int spifd;
static uint8_t mode = SPI_MODE_0;
static uint8_t bits = 8;
static uint32_t speed = 1500000;
#endif
*                       INIT AND EXIT CODE                             *
    rtapi_print("Info: Initialize SPI5 connection\n");
    spifd = open("/dev/spidev0.0", O_RDWR);
    if (spifd < 0) {
        rtapi_print_msg(RTAPI_MSG_ERR,"Failed to open SPI device\n");
        return -1;
    // Set SPI mode
    if (ioctl(spifd, SPI_IOC_WR_MODE, &mode) == -1) {
        rtapi_print_msg(RTAPI_MSG_ERR,"Failed to set SPI mode\n");
        close(spifd);
        return -1;
    // Set bits per word
    if (ioctl(spifd, SPI_IOC_WR_BITS_PER_WORD, &bits) == -1) {
        rtapi_print_msg(RTAPI_MSG_ERR,"Failed to set bits per word\n");
        close(spifd);
        return -1;
    // Set max speed
    if (ioctl(spifd, SPI_IOC_WR_MAX_SPEED_HZ, &speed) == -1) {
        rtapi_print_msg(RTAPI_MSG_ERR,"Failed to set max speed\n");
        close(spifd);
        return -1;
#endif
//Edit rtapi_app_exit function, add close(spifd)
void rtapi_app_exit(void)
    close(spifd);
    hal_exit(comp_id);
//In fuction void rio_transfer()  near end of it add:
    struct spi_ioc_transfer tr = {
        //.tx_buf = (uint64_t)tx_buf,
        //.rx_buf = (uint64_t)rx_buf,
        .tx_buf = (uint64_t)txData.txBuffer,
        .rx_buf = (uint64_t)rxData.rxBuffer,
        .len = SPIBUFSIZE,
        .speed_hz = speed,
        .delay_usecs = 0,
        .bits_per_word = bits,
    // Perform SPI transfer
    if (ioctl(spifd, SPI_IOC_MESSAGE(1), &tr) == -1) {
rtapi_print_msg(RTAPI_MSG_ERR,"Failed to perform SPI transfer\n");
        //close(spifd);
        //return -1;
#endif
//Save and do hallcompile...
2 years 5 months ago #301069 by meister
Thanks,
I think the problem with RPI5 and SPI was that it is not realtime-capable. But I don't know exactly, I don't have an RPI5 yet.
I'm looking forward to the first machine tests
The following user(s) said Thank You: Zayoo
2 years 5 months ago #301070 by Cant do this anymore bye all
It's not so much it isn't "realtime capable" but since the SPI interface was moved to the RP1 chip, none of the former Rpi 4 code works.
Going thru /dev/spi doesn't appear to be fast enough, at least for the mesa cards.
2 years 5 months ago #301094 by Zayoo
Here is demo video:
Since implementing this solution, I haven't experienced any communication issues. I can't say the same for previous tests where I used a laptop and a W5500 chip.
While researching the topic, I came across cases where people use spidev kernel libraries to manage several displays. They even mention 200Mhz clocks what is hard to believe. Official RPi pages stays on maximum 50Mhz. So speed should not be issue and "realtime capable" out of my understanding. :)
I'm working on 1.5Mhz. I'm still learning and even don't know what is acceptable speeds. from orginal BMC library i extract some data that speed should be around 1.5Mhz.
The following user(s) said Thank You: tommylight, meister, besriworld
2 years 5 months ago #301349 by meister
The following user(s) said Thank You: tommylight, Zayoo
2 years 5 months ago #301610 by meister
what the hell is wrong with me :)
www.youtube.com/shorts/tQvyrIP7aVc
but i have a serious problem with the kinematic, i need only 4joints, but the melfa stuff have 6 :(
don't know how to setup a 4dof robot the right way :(
Time to create page: 0.098 seconds
